I have a '99 Nissan Maxima SE with tire size 215/55-16 that I'd like to get four new tires before winter hits.
After doing much research and after selling my dedicated winter wheel/tire set from this vehicle, I need to buy a good all around tire that will do okay in the snow, wet, provide a long service life and offer a quite ride on the highway.
My research came down to Yokohama Avid V4S and Michelin Primacy MXV4 (available in both H and V rated). After doing further research and Michelin having a $70 rebate out there, I've concluded that the Michelin tires will do better in the winter than the Yokohama even though they are a bit more expensive.
I'm now comparing the Primacy MXV4 H rated against the V rated and see no difference in the specs. They even both offer a 60k mile tread life warranty.
So, what's the difference between the H rated and the V rated other than the top speed capability and price? Both have the same exact specs according to TireRack and same tread pattern. Does the V rated provide a more reinforced sidewall that will flex less in turns but maybe provide a harsher ride?
