Saab MTF0063 VOA and UOA @ 32786mi
JHZR2
Staff member
New Jersey
Hello,
My 04 Saab 9-3 has been a great car. Last spring, I decided that I'd change the MT fluid. It was tough, since the drain plug is covered by a suspension member (good luck getting it out). As a result, I used my liqivac to remove, then a fluid pump to refill. It took about 1.5L to refill, as claimed in the directions, shown here:
http://www.genuinesaab.com/psi/files/93-95man-oil.htm
The fluid is MTF 0063. It is a different fluid than the older synthetic manual transmission fluid that was used in older saabs. I am not sure if this fluid supercedes the older synthetic fluids, but it is what is used in my 9-3.
Anyway, the first column is virgin, the second column is used with 32786 miles.
Code:
Sample Date 6/19/08 2/26/08
Unit Age 0 32786
Comp Age 0 32786
Time on Oil 0 32786
Time on Fltr 0 0
Oil Maint. New changed
Fltr Maint. New NONE
Fluid Saab MTF 0063 Saab MTF 0063
Fe 0.9 85
Cr 0.2 0.9
Ni 0.9 3.2
Ti 0 0
Ag 0 0.3
Al 0.9 7.1
Pb 1.7 49
Cu 0 71
Sn 0.2 0
Si 6.5 24
Na 0 11
K 0 22
B 0 16
Ba 0 5.7
Mo 0 0.1
Mg 14 9.1
Ca 3610 2666
P 2095 1608
Zn 1725 1388
S 5923 6331
Cd 0 0
Mn 1.3 1.3
V 0 0
Sb 0 0
Kv@
40°C 70 58.18
100°C 13
White
Metal NONE LIGHT
Babbitt NONE NONE
Precipitate NONE NONE
Silt NONE NONE
Debris NONE NONE
Dirt NONE NONE
So the Saab uses a light 75W90 mtl. Next time you may want to also get the before and after TAN readings.
The oil did shear somewhat. I would say 35k is a good OCI for this fluid/tranny combo.
Thanks!
I sure appreciate the insight. Any thoughts on what other available 75w-90 "light" MTLs might be a good option? THis fluid does seem to be a bit stiff in the extreme cold (i.e. 10F around here), whereas my amsoil MT fluid still is pretty nice.
I found MTF to be quite stiff and whiney in my 01 in the winter time. I switched to Redline MTL, and it is much smoother all around. Currently its -25C here :(, and I still have fairly smooth shifting at cold and no more tranny whine. I am very happy with the MTL.
Thanks for posting this.
I've got 84,000+ miles on the 2004 9-5 5sp. According to the owners manual the MT fluid is a lifetime fill!!
I guess I'll plan a drain/refill it this spring. Thanks
I have used both MTL and MTF0063 in a 9000 which has practically the same gearbox. The 0063 was good, but as Saab9-3 said, MTL is excellent especially in the cold.
Actually it appears to be a 75W85, not 75W90. Redline now makes a 75W85 GL4 trans fluid. The 85 spec is 11.0 to 13.5.
But the high Ca level makes me think it may have a lot of detergency. Saab must think detergency is important. I'd ask Redline re detergent content in their GL4s before using them.
The high Ca and almost 1:1 Zn:p ratio means this stuff may be derived from a motor oil, maybe a 5W30 or light 0W40. Evidently it has >1.5% ZDDP, which is not usually used much in dedicated transmission oils.
Charlie
