I've had the car a little over 100,000 miles. Previous oil had been Mobil1 in 5W30 or 10W30 (depending on season) with 5000 mile changes during that time. This is the first fill of Redline. Filter's are dealer replacement. The air filter has been in there for about forever. The oil filter is 90915-YZZF1.
The car sees some track. That was the reason for the switch. I was told that the oil temperaures could go north of 300°F while out there.
The two samples were close together because the first was the day before the track weekend and the second is after including the drive up and back and then some normal commuting. No oil change. Here's a sound clip of the severe service it sees (from july). Normally we get six sessions of ~20 minutes.
There was no make-up on the first sample. The second is with 1/2 quart. I was warned to keep it a little overfull because of pickup problems in the turns.
Code:
3950 oilMiles 4886 oilMiles
158971 carMiles 159907 carMiles
Iron 5 5
Chromium 0 0
Nickel 0 0
Aluminum 3 3
Lead 2 2
Tin 0 0
Cadmium 0 0
Silver 0 0
Titanium 0 0
Vanadium 0 0
Silicon 16 16
Sodium 14 15
Potassium 0 0
Molybdenum 631 637
Antimony 0 0
Manganese 0 0
Lithium 0 0
Boron 5 5
Magnesium 12 12
Calcium 2827 2853
Barium 2 2
Phosphorous 1281 1305
Zinc 1311 1315
Fuel
Soot
Water
Viscosity 10.1cSt 10.0cSt
TBN 5.68 5.27
The Silicon doesn't bother me. The VOA had 15.
The oil is still in the car. I may sample again before I change it.
dB
Code:
Iron 5 5
Chromium 0 0
Nickel 0 0
Aluminum 3 3
Lead 2 2
Tin 0 0
Cadmium 0 0
Silver 0 0
Titanium 0 0
Vanadium 0 0
Silicon 16 16
Sodium 14 15
Potassium 0 0
Molybdenum 631 637
Antimony 0 0
Manganese 0 0
Lithium 0 0
Boron 5 5
Magnesium 12 12
Calcium 2827 2853
Barium 2 2
Zinc 1311 1315
Fuel
Soot
Water
TBN 5.68 5.27
dB
