I have a 1997 maxima, and its rebuild tranny has been acting up a bit. The change from 1 to 2 is noticeably rougher that all the other gear changes, and in the winter I have to wait for it to warm up before the gears change normally, otherwise I will move the shifter but nothing happens. I have changed the tranny fluid every 30 k or so at local shops, but maybe someone has suggestions as to how to proceed. Is there a better fluid than others that I should use at the next change that will prolong the life of this transmission, and help it through the coming winter? I'm on Long Island, so we get some cold temps from the ocean.
thanks in advance
thanks in advance
