HynKia Carquest filters: 85334 vs 95459
by SlavaB. 06/19/19 11:26 AM
Shell Spirax S1 alternatives
by avacado11. 06/19/19 10:38 AM
ZF HP8 Transmission Servicing
by Joel_MD. 06/19/19 08:50 AM
HF flashlight recall = 5 dollar gift card
by 1978elcamino. 06/19/19 08:41 AM
Cam pics of 2007 Fusion
by tig1. 06/19/19 08:27 AM
LS Diff gear oil
by WyrTwister. 06/19/19 07:55 AM
2005 BMW 325i, 12,065 miles, Mobil 1 0W-40
by Toto. 06/19/19 07:50 AM
Mortgage Lenders, FHA Guidelines Question
by diyjake. 06/19/19 07:15 AM
rare AWD comparison test of CUVs on same tires
by madRiver. 06/19/19 07:08 AM
195/65R Yokohama Avid Ascend GT
by Marco620. 06/19/19 01:01 AM
New frontier 4.0 V6
by passgas55. 06/19/19 12:14 AM
Top 5 reliable, affordable car makers?
by Elkins45. 06/18/19 10:16 PM
Rear positive camber
by wing0. 06/18/19 09:44 PM
Odd vehicle / tags on I-70
by Marco620. 06/18/19 09:43 PM
Repainted bumper cover vs OEM
by DTS419. 06/18/19 09:37 PM
Sweet Ice Tea
by BlueOvalFitter. 06/18/19 09:30 PM
17 F150 6R80 ATF oil change
by MagneticFX. 06/18/19 08:49 PM
Ignatius, Kyle_O, DTS419, chakir, 9J460
68431 Registered Users
87 registered members (1978elcamino, aquariuscsm, 92saturnsl2, AnthemBassMan, ammolab, Aichiguy, 9 invisible), 2,151 guests, and 30 spiders.
Topics290,655
Posts4,990,475
Members68,431
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Redline Engine Break-In Additive #1199486
07/22/08 04:15 PM
07/22/08 04:15 PM
VA
Taylor Offline OP
Taylor  Offline OP
VA
Thoughts?
Re: Redline Engine Break-In Additive [Re: Taylor] #1199518
07/22/08 05:01 PM
07/22/08 05:01 PM
NV
wcbcruzer Offline
wcbcruzer  Offline
NV
Another product to sell to people who will buy anything.
1996 Dodge Ram, 12v Cummins, 4x4, 47RE, ext. cab, long bed
Re: Redline Engine Break-In Additive [Re: wcbcruzer] #1199649
07/22/08 08:01 PM
07/22/08 08:01 PM
VA
Taylor Offline OP
Taylor  Offline OP
VA
Re: Redline Engine Break-In Additive [Re: Taylor] #1199776
07/22/08 10:48 PM
07/22/08 10:48 PM
Bohica
D-Roc Offline
D-Roc  Offline
Bohica
What would be the purpose of using that product????
Re: Redline Engine Break-In Additive [Re: D-Roc] #1199802
07/22/08 11:26 PM
07/22/08 11:26 PM
Pacnw
saaber1 Offline
saaber1  Offline
Pacnw
from their website:
"provides conventional motor oils with antiwear additives like zinc and phosphorus (ZDDP) necessary to protect against camshaft and valvetrain damage on break-in.
This is especially important in flat-tappet engines where bigger camshafts grinds and higher valve spring pressures are now popular. This additive is designed to allow pistons rings to seat properly, while allowing other engines components to avoid excessive wear."
http://www.redlineoil.com/products_motoroil.asp?categoryID=1
I am curious about it because the guys who tune vw 2.0 turbo engines report problems with cam follower wear mainly when running aftermarket high pressure fuel pumps (which run off of a cam follower).
These guys run some seriously high horsepower for such a small engine and can take a motor probably up to or beyond it's limits, (running as high as 26 psi boost).
One benefit of that is it finds an engine's weak points so that when using the engine in stock form you can account for those weak spots (note that I always try to make ever engine last forever and under normal circumstances it may not be an issue), in this case added cam/cam follower protection. I am just breaking in my car so I may give this a try to protect the cam/follower during break in.
"when 5W30 is cold, ...the oil is 35 weight (5+30),...20 w 50 starts at 70 and warms up to 50"
- Kyle, auto mechanic & VP Speedline Motorsports, INTL
Re: Redline Engine Break-In Additive [Re: saaber1] #1200373
07/23/08 08:34 PM
07/23/08 08:34 PM
VA
Taylor Offline OP
Taylor  Offline OP
VA
Very important when BREAKING IN a motor of this caliber. Not the first couple thousand miles, but the initial 20 min break-in above 2k rpms, and 1st 500 mi oci. Im not claiming your motor will lockup if you don't use a break in add, but this stuff gives a little extra protection. Not so much a modern motor, but you will notice many manufacturers factory fill is specially formulated for break-in.
Re: Redline Engine Break-In Additive [Re: Taylor] #1200379
07/23/08 08:42 PM
07/23/08 08:42 PM
VA
Taylor Offline OP
Taylor  Offline OP
VA
You don't want to load the motor with ZDDP, as super high levels may be good for the cam but the pistons don't benefit as much and don't seat well. This additive is a good balance that allows the pistons to seat while still protecting the cam, and it is ester based.
Re: Redline Engine Break-In Additive [Re: Taylor] #1200510
07/23/08 10:39 PM
07/23/08 10:39 PM
Australia
4banga Offline
4banga  Offline
Australia
But wouldnt that depend what oil your adding it to in the first place? If you added it to something like 15w 40 Delvac which has allready high ZDDP would you now have too much?
Re: Redline Engine Break-In Additive [Re: 4banga] #1200592
07/24/08 12:31 AM
07/24/08 12:31 AM
Pennsylvania
KA426 Offline
KA426  Offline
Pennsylvania
I use five quarts of Penn Grade 1 SAE 30 break-in oil.
Re: Redline Engine Break-In Additive [Re: 4banga] #1200770
07/24/08 09:27 AM
07/24/08 09:27 AM
VA
Taylor Offline OP
Taylor  Offline OP
VA
Yes the finial level would depend on the sarting point, but remember this is just breakin not a full oci, 20 min pull above 2k rpm's and a 500 min run. I don't really like the idea of a 15w40 for breakin considering the oil will hardly get up to temp. I use 0wX for it's cold flow properties, and boost the AW levels with an add like this.
Re: Redline Engine Break-In Additive [Re: Taylor] #1201969
07/26/08 12:55 AM
07/26/08 12:55 AM
By Detroit
TallPaul Offline
TallPaul  Offline
By Detroit
This stuff would be great for boosting your regular engine oil. I'd run a boost of at least 200 ppm phosphorus, maybe 400 for heavy duty use.
Obnoxious seems to be the styling cue for modern automotive design.
Re: Redline Engine Break-In Additive [Re: TallPaul] #1203903
07/28/08 10:48 PM
07/28/08 10:48 PM
The Rocky Mountains
pickled Offline
pickled  Offline
The Rocky Mountains
For high HP motors that we knock together (> 1.5 HP/Cubic Inch) with flat tappets I always break them in on HDEOs and really glob the assembly lube on the lobes and lifters. Run for the first 20 minutes with the throttle up then change oil and filter out while it's hot. We haven't had issues after following that procedure...except for the one time someone left a wing nut sitting on the carb's butterfly that wasn't good!
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
Re: Redline Engine Break-In Additive [Re: pickled] #1206563
08/01/08 03:49 PM
08/01/08 03:49 PM
VA
Taylor Offline OP
Taylor  Offline OP
VA
Im not saying you cant, I just finished breaking-in a motor with straight RTS.
Re: Redline Engine Break-In Additive [Re: Taylor] #1207841
08/03/08 08:12 PM
08/03/08 08:12 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Here is one formula for determining new ppm levels.
(Additive oz. x PPM + Oil oz. x PPM)/(oz. of Additive + oz. of PCMO) = new ppm
E = M*C^2; I.e., Energy = Milk*Coffee^2
Re: Redline Engine Break-In Additive [Re: MolaKule] #1208574
08/04/08 10:46 PM
08/04/08 10:46 PM
moutain country
boxcartommie22 Offline
moutain country
molakule,could you explain more on what all the formula means etc.additive oz. ppm of what? oil oz.of what? oz of additive? oz of pcmo?amt of oil added to sump?
thankyou
2001 Lincoln Conti,RL,K&N,Hotshots,Lubegard,Archoil
2007 Grand Marquis,RL,K&N,Hotshots,Lubegard,Archoil
2010 Raptor,RL,Hotshots,Lubegard,Archoil
Page 1 of 5 1 2 5
