Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
110 registered members (aleneros, 240_Ed, Al, 17 invisible), 1,648 guests, and 54 spiders.
Topics284,602
Posts4,873,195
Members67,298
Most Online2,548
Feb 16th, 2019
Toyota coolant any good? Alternatives? #1015746
10/23/07 12:29 AM
10/23/07 12:29 AM
Canada,North America,Western H...
byez Offline OP
byez  Offline OP
What type of change interval would you recommend for mostly city driving? Manual says every 32 km/20 miles. Is that a bit aggresive considering this is labelled as "long-life coolant"?
Re: Toyota coolant any good? Alternatives? [Re: byez] #1015747
10/23/07 12:38 AM
10/23/07 12:38 AM
byez Offline OP
byez  Offline OP
sorry wrong section, please move, thanks
Re: Toyota coolant any good? Alternatives? [Re: byez] #1015748
10/30/07 03:36 AM
10/30/07 03:36 AM
Ball, LA
02zx9r Offline
02zx9r  Offline
Ball, LA
From what others have said, the toyota red and pink coolant are very good. I have the pink (super long life) coolant from the factory in my corolla. I am planning on draining/refilling with pink in either 2 years or 50K. Good preventative maintenance
2012 Honda Insight EX
Re: Toyota coolant any good? Alternatives? [Re: 02zx9r] #1069932
01/22/08 08:31 AM
01/22/08 08:31 AM
north carolina
mikeg5 Offline
mikeg5  Offline
north carolina
like any coolant the key is the change it every 20-50k miles. if you live in severe climats whether cold or hot i would go with 30k miles whether it says long life or not. this will keep from the need of flushing. just drain and fill. its easy...
-- btw you can use the green prestone (any make, any model) coolant in toyotas. its cheaper than yota stuff. just change it out every 30k. it will be fine.....
02 Toyota Tacoma 4 door 3.4 v6 4X4
150k miles. Amsoil in the diffies and tranny
05 Corrola LE 145k miles auto
Re: Toyota coolant any good? Alternatives? [Re: mikeg5] #1070488
01/22/08 08:46 PM
01/22/08 08:46 PM
Columbia, SC
wantin150 Offline
wantin150  Offline
Columbia, SC
Toyota Pink = 100k (first change), 50k thereafter. I plan to drain and refill every 50k. Prediluted 50/50
Toyota Red = 30k. I flushed it at 30k and 60k. Just plan on drain and refill every 15k here on out. Must add water.
2003 Toyota Matrix XRS 87,000 miles
2008 Scion xD 14,500 miles
2007 Yamaha YZF600r 8,400 miles
Re: Toyota coolant any good? Alternatives? [Re: byez] #1077326
02/01/08 10:25 PM
02/01/08 10:25 PM
Washington, DC
Rolf Offline
Rolf  Offline
Washington, DC
Toyota's current red coolant is an OAT (Organic Acid Technology, like DexCool), which like most Japanese coolants contains phosphates but no silicates.
It differs from DexCool primarily in that it lacks 2-EHA, which Toyota seems to believe creates some problems with gaskets.
From what I've seen the current Honda Coolant is about the same despite the color difference.
If you own only Toyotas their coolant makes a lot of sense.
Universal antifreezes, which are usually some version of a DexCool clone, often contain 2-EHA, which is something of a no-no.
In my own fleet, which includes a Toyota which came with the red fluid, a Hyundai, and an '06 Malibu I've settled on G-05, which is factory fill on Ford, Chrysler, Mercedes, and some others.
The slight trace of silicates doesn't seem to cause any problems in years of use, it avoids the low coolant problems that arise with DexCool and its clones, it's long life, and it's pretty much as close to a universal coolant I've been able to find.
Re: Toyota coolant any good? Alternatives? [Re: Rolf] #1090717
02/21/08 06:53 PM
02/21/08 06:53 PM
N. Michigan
ocrstar Offline
ocrstar  Offline
N. Michigan
DexCool and Toyota Red must be pretty close, because Toyota uses the red/pink in the Matrix; and GM uses DexCool in the Pontiac Vibe, which are the same cars with same engine.
Re: Toyota coolant any good? Alternatives? [Re: ocrstar] #1099442
03/05/08 01:46 PM
03/05/08 01:46 PM
Georgia
Georgiadave Offline
Georgiadave  Offline
Georgia
The phs of Prestone green and Toyota red are 11.1 and 6.8, according to a virgin coolant analysis on this tread. 1-7 is acid, 7-14 alkaline. So there is a basic difference in the chemical composition of the two. Levels of silicon, boron, molydenum, and phosphorus are also quite different. I do not think they are interchangeable and do not think green is compatible with Toyota.
Re: Toyota coolant any good? Alternatives? [Re: Georgiadave] #1100649
03/07/08 08:56 AM
03/07/08 08:56 AM
north carolina
mikeg5 Offline
mikeg5  Offline
north carolina
dave to your dismay people have been running green coolant in yotas for years and years with little or no issues. the key is the change the fluid regularly 30k miles or less since it isnt a long life coolant.. also use distilled water
Re: Toyota coolant any good? Alternatives? [Re: mikeg5] #1101043
03/07/08 08:32 PM
03/07/08 08:32 PM
Georgia
Georgiadave Offline
Georgiadave  Offline
Georgia
I am not dismayed at all. The fluids are manifestly not the same. Where is your data?
Re: Toyota coolant any good? Alternatives? [Re: Georgiadave] #1135097
04/22/08 08:23 PM
04/22/08 08:23 PM
Brooklyn, NY
parimento1 Offline
parimento1  Offline
Brooklyn, NY
I have been using regular green in my Toyota Avalon for 8 years (as a matter of fact, I just drained and filled it Friday) and never had a cooling problem- no leaks, no nothing. Thats just my own experience. Car is a 97 Avalon
Re: Toyota coolant any good? Alternatives? [Re: parimento1] #1141735
05/01/08 04:05 PM
05/01/08 04:05 PM
USA
JohnBrowning Offline
USA
My Dad has been useing Dex Cool in his 1995 Tacoma for a long time. Recently I replaced his thermostat and flushed the system. Since the water here in Michigan is hard I decided to use Zerex G-05 this time around. THe water was softened tap water. So far no problems at all. As long as you do not have coolant that pass's through plastic pieces I do not think their is anything wrong with useing Dex-Cool in a pinch. I prefer G-05 because I am familar with it and know that it works well even with hard water and that it is safe to use even when coolant pass's through plastic parts!
So as long as you are flushing I would think G-05 or Pentosin would be my first choices followed by all others.
Re: Toyota coolant any good? Alternatives? [Re: JohnBrowning] #1141776
05/01/08 05:06 PM
05/01/08 05:06 PM
Sudbury, ON, Canada
firemachine69 Offline
Sudbury, ON, Canada
JohnBrowning:
Is that G-05 the Dex-Cool compatible stuff? Or their other universal A/F?
Cheers, sounds like this could be a good substitute.
I have a very bad mem... What were we talking about again?
Re: Toyota coolant any good? Alternatives? [Re: firemachine69] #1141792
05/01/08 05:28 PM
05/01/08 05:28 PM
Florida
artificialist Offline
Florida
G-05 is NOT Dex-Cool compatible. G05 uses Silicates and Borates.
2010 Lancer Ralliart Sportback
Re: Toyota coolant any good? Alternatives? [Re: artificialist] #1141798
05/01/08 05:34 PM
05/01/08 05:34 PM
Sudbury, ON, Canada
Sudbury, ON, Canada
Thanks for the heads up.
Would you choose to run a previously-filled Dex-Cool vehicle with G-05?
Moderated by  ekpolk
