A portable one, that is, a "Rally" brand if I recall right, bought about 10 years ago when the factory jack for my Olds Cutlass proved woefully inadequate.
I'm planning a road trip, and after pumping the compact spare tire up to 60 psi, I checked my aftermarket jack. It would pump up a little, but not enough to lift the car.
It has a filler hole for the oil reservoir. No indication, however, what kind of fluid to use. ATF, power steering fluid, or even engine oil?
