Home
Lucas oil stabilizer
Posted By: daz
Lucas oil stabilizer - 06/05/18 09:08 PM
I started using this and i really like the way it has made my triumph thunderbird run. But i used only half the quart. Seems like a quart is a lot to put in a bike that holds 4.5 quarts of oil. So the question is, does anyone here use it and if so how much do you typically put in your bike and whats you bike's oil capacity?
Posted By: Dyusik
Re: Lucas oil stabilizer - 06/05/18 09:18 PM
No one. It is an oil type from 1905, and it has a viscosity 10 times that of a light 40 weight. Just bump up a grade in an oil choice to get the same results without compromise.
Posted By: SirTanon
Re: Lucas oil stabilizer - 06/05/18 09:33 PM
No way would I put that in either of my cars crankcases.
Posted By: Billbert
Re: Lucas oil stabilizer - 06/05/18 09:38 PM
Do you really want to dilute the additive package so carefully formulated by the manufacturer of your oil by 10-20% ?
Posted By: BigCahuna
Re: Lucas oil stabilizer - 06/05/18 10:15 PM
In all my years of riding, my oil has never needed to be stabilized.,,
Posted By: mx5miata
Re: Lucas oil stabilizer - 06/05/18 10:50 PM
isn't that stuff labeled replace 20% of oil capacity with the lucas
Posted By: skyactiv
Re: Lucas oil stabilizer - 06/05/18 10:56 PM
A video is worth a thousand words.
Posted By: daz
Re: Lucas oil stabilizer - 06/06/18 02:28 AM
Well, i didn't post this to get opinions on whether it's good or not, but since almost all of you seem to assume it isn't, i'll just say this. Suggesting it's bad without any experience, especially long term, would be call an "assumption". There are 1000's of reviews on this stuff many of which i read and are almost all positive that are from users who HAVE EXPERIENCE WITH IT and are not just assuming based on their logic, which by the way unless you are a engineer in the field means little to nothing. If all it took was layman's logic and learning what u know by reading posts by others inexperienced with it to determine what will or won't work, there would be no debates and all products on the market would work. Now, excuse me while i find another place that might answer what i asked rather then revel in the joy of raining on someone's parade without actually knowing whether your raindrops are even valid. Good day...
Posted By: spasm3
Re: Lucas oil stabilizer - 06/06/18 02:38 AM
When you post about a subject on a forum, its open to discussion, otherwise, why bother to post. You say that suggesting its bad without experience is an assumption.
Well there is data here about whats in lucas. So that's experience. Here is a voa thread.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/890132/8
There is little there other than thick base oil without additives.
Time to face the facts. If that bothers you, don't make assumptions that a product is good , just because you pour it in and nothing bad happens. It could also be nothing good is happening either.
Posted By: talest
Re: Lucas oil stabilizer - 06/06/18 02:52 AM
It is a straight 80-weight bottle of snot with soap in it. No thanks.
As stated, going up one grade of oil should yield similar results and not compromise the oil.
Posted By: PeterPolyol
Re: Lucas oil stabilizer - 06/06/18 03:01 AM
Why are bright stock products so bleddy expensive?? A dinky bottle of STP costs as much as a quart of synthetic oil. A quart of Lucas costs as much as a 5L jug of synthetic. Are the merchants of such products just blatantly ripping people off?
Posted By: 4WD
Re: Lucas oil stabilizer - 06/06/18 03:19 AM
Do they really have a stadium?
Posted By: Shannow
Re: Lucas oil stabilizer - 06/06/18 04:04 AM
Couple of qualifiers here
* I HAVE used it in the past in my engines (I was an idiot)
* I AM an engineer
* In my turbine engineering days I DID use it on bearings during turbine overhauls.
Firstly - it makes oil thicker...for better or for worse
Secondly - being additiveless in and on itself, it dilutes your anti wear additive, your friction modifying additives, your detergents and dispersents.
So does the thickening offset the subrtractive effect on additives...unlikley.
The increasing thickness:
* will use more fuel - you may or may not be able to measure it.
* will affect your "W" rating, that is the cold weather performance of your oil - you can't and won't measure that.
So rather than being an "additive", the majority of what it does is "subtractive"...
* takes away your engine oil additive concentrations
* takes gas money out of your wallet
* takes away your cold weather performance
* takes away far more money than buying a properly formulated oil of the next grade up.
Now to why I used it on the turbines, it was SOOOO thick that it wouldn't squeeze out between the bearing and the journal (12"-20" diameter, 8-19" long), meaning that we could turn the shafts using the overhead crane without activating the shaft lifting oil system. Being essentially additive free, it didn't contaminate the bearings or the oil tanks.
Posted By: 02SE
Re: Lucas oil stabilizer - 06/06/18 05:09 AM
Forrest sure has made a lot of money selling his thick base oil to sucke.. err customers. It's been tried in Fuel cars, AFAIK no one is actually using it.
Posted By: mx5miata
Re: Lucas oil stabilizer - 06/06/18 09:15 AM
You're going to get all sorts of opinions when you post - I wouldn't take it to heart.
My mechanic friend used this stuff back in the late 90s in a civic as a topoff or 80/20. He swore by it and had no issues. And thats all he would do 80/20.
I would sooner try the pure synthetic stabilizer but not in a brand new vehicle especially under warranty.
I'm not one to alter my oils chemistry or mask problems with oil thickeners. Only if the vehicles on its last leg.
Posted By: Shannow
Re: Lucas oil stabilizer - 06/06/18 09:28 AM
Swore by it...what benefits did he obtain/measure by it ?
Had no issues...Nothing blew up is the new BITOG standard. ASTM, SAE, and the OEMs hold lubricants to a far higher standard than not blowing up.
Posted By: alarmguy
Re: Lucas oil stabilizer - 06/06/18 10:58 AM
No I dont use it and never would, as I buy API certified oils and it doesnt make sense to turn it into a non certified oil by adding foreign elements to it.
Posted By: mx5miata
Re: Lucas oil stabilizer - 06/06/18 11:11 AM
could have been "all in his head" lol
he had a more aggressive cam and valve train work said when he did a visual inspection for wear he liked what he seen.
probably liked the boost in oil pressure when the vtec hit in... anyway he had the car for several years and it ran just fine.
Posted By: BJD78
Re: Lucas oil stabilizer - 06/06/18 11:18 AM
Exactly, No modern engine oil, conventional, semi, or synthetic need to be "stabilized" and I have yet to see any owner manual or lube order calling for additives to be put into the engine. Millions and millions of vehicles have went well over 200K to 300K and beyond by using only the weight and grade of oil called for by the manufacturer. The Lucas spinner thing is good for kids or bored adults to crank on and kill time while the parts clerks looks up the parts you need, but other than that it is just fancy marketing for a product that a vehicle does not need. Parts stores seem to have no end of magic grass fed organic snake oils for oil, fuel, transmissions and the like and apparently no end of customers who buy the stuff.
Posted By: LoneRanger
Re: Lucas oil stabilizer - 06/06/18 11:29 AM
You shouldn't put an extra additive in a shared sump bike. Not the best idea for a wet clutch. Doing so will kill the JASO MA or MA2 compliance of whatever motor oil you use. If you use JASO MA/MA2 compliant oil. Which you should in a shared sump ...
Posted By: racin4ds
Re: Lucas oil stabilizer - 06/06/18 01:47 PM
I don't use the Lucas but I do use the STP stuff, its just as thick and at least has ZPPD and other additives! Works great in high mileage engines that make a little noise, quiets them right up!
Posted By: 4WD
Re: Lucas oil stabilizer - 06/06/18 02:41 PM
If STP works Ö test to determine what grade you modified the oil to and buy that Ö
Most here would agree thatís an actual engineered and balanced formula Ö
Re: Lucas oil stabilizer - 06/06/18 05:03 PM
You do realize this is in the motorcycle forum, yes? STP friction slickerizer additive and a wet clutch...hummm.
Posted By: Brian553
Re: Lucas oil stabilizer - 06/06/18 05:05 PM
Daz, I've been in this same boat as I really liked what the Lucas product was. (technically I still do, to a sense.)
I really wanted a way to make it work with my own cost savings by mixing it or using it in some utilitarian way.
But Shannow in his first post really has hit the nail on the head, and the product has had a difficult time as a result to make it or stay in anyone's garage from this forum.
We all want you to get the most juice from the squeeze you put out. I do think it is making your bike feel better right now, but using Lucas is not the only way to get there, and there are better ways that won't also corner you into spending an arm and a leg for it. You can post or PM any of us and we can help give you a solution.
I know you didn't ask for it, but although using lucas (syn or original) helps to protect/fix against over-shearing (also quieting down the valvetrain and making the shifting feel a little smoother), you could also switch to a higher cold-temp weight--higher first number i.e. 10wXX to 15 or 20wXX--for protecting against over-shearing and higher high-temp weight--higher second number i.e. XXw40 to XXw50 or XXw60--to quiet the valvetrain down. (both of these should help with the shifting, too.)
Bottom line, I think Lucas does what it advertises, but does also shorten the life of your oil via dilution of detergents and anti-wear additives, which it doesn't advertise (which obviously no one should expect in an advertisement.)
If you gotta tinker midway through or something like that, then swap the Lucas for a straight-weight detergent-containing oil like SAE 30. Delo or Rotella or Supertech, whichever.
Hope you're still reading..
Posted By: TiredTrucker
Re: Lucas oil stabilizer - 07/08/18 12:28 PM
I suppose it is an assumption that LOS is nothing more than an oil thickener with nothing beneficial to add to the game, but it is also an assumption that it does provide some miraculous cure the intended oil could accomplish. For every one of those engines that some would claim LOS was the major factor in its longevity, a dozen can be produced that went just as long or longer by simply using the intended oil in them.
What is conspicuously absent from all of Forrest Lucas' marketing is a ton of third party testing and SAE results that LOS actually is what it claims to be and provides what it claims to provide. Having race car drivers tout the stuff means nothing. They are doing that because they are paid to do it. I am just unclear how the LOS stuff became so popular with the lack of actual testing and certifications.
Posted By: Shannow
Re: Lucas oil stabilizer - 07/08/18 09:04 PM
No, just like mileage reduction on Ethanol is science, not supposition, Lucas is as I've stated, without supposition or assumption.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/890137/Re:_Lucas_Oil_Stabilizer#Post890137
Originally Posted By: Shup1
Here is the skinny on LOS
Unless listed all are 'Zero'
Lucas Virgin
TBN - 0.1
Visc - 615.3
FP - 435
Calcium - 3
Magnesium - 1
Phosphorus - 4
Zinc - 2
Rotella T / LOS 5 to 1 blend
TBN - 8.5
Visc - 115.4
FP - 420
Boron - 17
Silicon - 2
Calcium - 1442
Magnesium - 7
Phosphorus - 604
Zinc - 817
Does anyone have any feedback on Rotella blend, have I diluted it since it is a 5 to 1 mix??? or 83.33% Rotella / 16.67% Lucas
Posted By: DoubleWasp
Re: Lucas oil stabilizer - 07/09/18 01:49 PM
Lucas and K&N had the good fortune of having blown up in an era where the only scientific requirement necessary to sell a product was to pay enough people to say they like it.
Lucas does serve a purpose, though. If you pour it into an engine that is so messed up that it doesn't work right anymore, it will do a passable job of convincing a person that it actually works somewhat better.
Posted By: Dyusik
Re: Lucas oil stabilizer - 07/26/18 12:18 AM
Similarly saw dust was used in rear ends to make it to the poor sucker that was about to inherit it [the problem] for a price too high.
Posted By: Idahokid
Re: Lucas oil stabilizer - 07/30/18 01:59 AM
I use the lucas Oil stabilizer in my Harley.I use it in the transmission and primary.When I drain the oil and wipe the oil pan with a paper towel it is super slippery.I also use it in the engine.I use lucas synthetic in the engine.Ive done UOA on lucas and Schaeferís and thereís no clear winner. Iím hoping it leaves that slippery film behind for cold starts.This is what I do and I know not everyone will approve but this is what I do.
Posted By: spasm3
Re: Lucas oil stabilizer - 07/30/18 02:09 AM
Its slippery because its oil. Nothing special about it. It is oil without any additives so its no more " slippery" than anything else just more viscous.
It actually dilutes the properties of the quality oil you are using and makes the whole sump a lower quality mix.
Its your engine, your money and this is America, use what you like. I won't let a bottle within 10 feet of my engines.
Posted By: Brian553
Re: Lucas oil stabilizer - 07/30/18 09:55 PM
Seems to be something you've practiced for a few years now. Care to Share the UOA's?
© 2020 Bob Is The Oil Guy
