Home
Need Help with Double D Knock Out Punch
Posted By: user52165
Need Help with Double D Knock Out Punch - 09/21/18 08:41 PM
OK - that got your attention, but it's not that.
Need a Greenlee double "D" knockout punch. Or equivalent.
3/4" x 2/3" - .75 x .67
It used to be a common size for electronics chassis - used to be............... that is 40+ years ago.
Some upward tolerance is OK.
Doesn't seem to be made now.
Ideas? Thanks guys.
Posted By: kschachn
Re: Need Help with Double D Knock Out Punch - 09/21/18 08:51 PM
Aren’t there a bunch of them for sale on eBay?
Posted By: gathermewool
Re: Need Help with Double D Knock Out Punch - 09/21/18 08:53 PM
Did you check the etherwebs?
Re: Need Help with Double D Knock Out Punch - 09/21/18 11:25 PM
Not that size.
Posted By: jhellwig
Re: Need Help with Double D Knock Out Punch - 09/22/18 03:53 AM
Unless you can find a Chinese knockoff or a used one on eBay you don’t have much options other than greenlee. There are a few meant for locks out there. Is it a lock application or electrical? If it is electrical you can find a good selection of 22mm or 30mm round devices.
Posted By: NYEngineer
Re: Need Help with Double D Knock Out Punch - 09/22/18 02:05 PM
In the past, I needed to make some D shaped holes for bulkhead connectors and I didn't have a D punch so I used a punch that was close and small and then filed one side flat and went at the rest with a round file to make up the diameter. Worked great but took some time. No where near as fast as a punch.
© 2019 Bob Is The Oil Guy
