Home
Battery Charger Pulsing?
Posted By: Auae85
Battery Charger Pulsing? - 10/10/18 01:11 AM
Drove my truck last Saturday night with no problems. Didn't drive the truck at all on Sunday or Monday. Went to crank it this morning and the battery was dead. I recently installed an AFM delete module on it, but I've let it sit for 3 or 4 days and had no issues, even with the AFM module plugged in the whole time.
Okay, so I unplugged the AFM module and put the truck on my battery charger, 2 Amp charge rate setting. Went out about 2 hours later, and the ammeter gauge was pulsing between 4 Amps and 6 Amps, and the battery wasn't accepting charging. I checked the connections to be sure they were good, even repositioning them, and the battery charger still pulsates. The battery is a Carquest Gold with a manufacturing date of 07/18.
Thoughts?
Posted By: dogememe
Re: Battery Charger Pulsing? - 10/10/18 01:16 AM
take the battery to get tested? just because it's new doesn't mean it's good.
Posted By: Warstud
Re: Battery Charger Pulsing? - 10/10/18 01:22 AM
Is it a smart charger ? Maybe the voltage of the battery is to low for the charger to detect.
Posted By: Auae85
Re: Battery Charger Pulsing? - 10/10/18 01:38 AM
Battery charger is an old Schumacher SE-82-6 12V dual rate charger. I inherited it from from my step-granddad over 20 years ago, and no telling how long he had it. I have charged a lot of batteries with it, and never seen this behavior before.
Posted By: Chris142
Re: Battery Charger Pulsing? - 10/10/18 01:49 AM
Mine does that when the battery is bad.
Posted By: eljefino
Re: Battery Charger Pulsing? - 10/10/18 02:01 AM
It could be a car computer/ relay trying to boot up now that the battery shows some voltage.
If your battery is flat it would take a 10 amp charge, easily. They're around 80 amp-hours so if you want to drive it this week, use the faster mode.
Next time you have your charger on a full battery, turn on your headlights. You'll see the current draw on the charger's ammeter.
The mode switch on buzz-box style chargers is pretty crude, as they like to say, YMMV.
The bad battery is certainly a possibility as well.
Posted By: mk378
Re: Battery Charger Pulsing? - 10/10/18 02:02 AM
Disconnect the battery from the truck electrical system. Charge for a couple of hours then measure the battery voltage. If it is stuck at less than 12 while charging, the battery has an internal short and needs to be replaced.
Posted By: Donald
Re: Battery Charger Pulsing? - 10/10/18 02:57 AM
Try charger on a known good battery. I say charger is shot. Get a smart charger.
Posted By: mk378
Re: Battery Charger Pulsing? - 10/10/18 12:52 PM
On a basic manual charger, the amp meter going up is good proof that it is working. The amp meter going higher than the nominal rated current means that something connected to the output is holding down the output voltage-- totally run down battery (which should resolve with charging for a time), defective battery, or load from the vehicle system.
The amp meter will normally fluctuate slightly with changes in the input line voltage, since there is no voltage or current regulator in the charger.
Posted By: Auae85
Re: Battery Charger Pulsing? - 10/10/18 01:53 PM
Thanks for the replies. I will check the battery charger on a known good battery to observe the ammeter, and I will try to charge the battery when it is disconnected from the truck. May have to wait a day or two due to work commitments and since we're starting to get some outer rain bands from the hurricane.
Posted By: HorseThief
Re: Battery Charger Pulsing? - 10/11/18 03:00 AM
The vehicle is trying to wake up and the charger can't supply enough current - this is very bad for electronics. Disconnect the battery before connecting the charger.
Posted By: Auae85
Re: Battery Charger Pulsing? - 10/12/18 04:06 PM
Well, thankfully all we got was slight winds and about 1-1/2 inches of rain from the hurricane since we were northwest of the main force. Anyway, yesterday afternoon I removed the battery from the truck and put in on the battery charger. No pulsing of the ammeter. I checked the voltage just prior to this, and it was approximately 4.61 volts. I left it on the charger for several hours and took it off last night before bed. Battery was now at 12.22 volts. Before leaving for work this morning, I checked it again, and it had dropped to 11.88 volts. I will check it when i get home to see if it has dropped any further.
Posted By: Auae85
BW, battery chager seemd to be working fine with no noises or odd smells.
Posted By: bbhero
Re: Battery Charger Pulsing? - 10/13/18 02:24 AM
What the voltage at now??? Seems a bit odd it dropped down after going up to 12.22.
Posted By: Auae85
Re: Battery Charger Pulsing? - 10/13/18 03:23 AM
Checked when I got home and it was approximately 11.5 volts. Had it on the charger since then; I'll disconnect the charger and check the voltage before going to bed, and then check it again in the morning.
Posted By: Auae85
Re: Battery Charger Pulsing? - 10/14/18 04:28 AM
Battery was at 13.17 volts when I went to bed, and 12.88 this morning. I took it to a parts store to have it checked; they did and said it was fine (passed the load test). Okay, reinstalled in the truck and drove around some today, with no problems. I'll watch it over the next few days. The truck is a 2009 GMC Sierra with 5.3L, and it has the adaptive charging system, so I may go get it tested just to be sure.
Posted By: eljefino
Re: Battery Charger Pulsing? - 10/14/18 02:30 PM
If you're checking the battery immediately after disconnecting the charger you'll get a falsely positive high reading.
That said I think the battery's toasted. Dropping to 4 volts is not good.
