90915-YZZD3 particle count - ISO code 24/23/15
Colorado
After seeing DuckRyders ISO code 24/23/15 for both the Fram Ultra and the HAMP filter, I sent in for a UOA from our RX330 -- I got back the same ISO code.
Oil had 5,659 miles, RX330 has 245,000+, Oil was PPHM 5W30, Filter was (oversized) 90915-YZZD3.
Intend to get a TG and try it at some point.
For those interested, full UOA posted to the UOA section.
[Linked Image]
Blackstone's PC test machine seems to be broken, lol.
Remarkably consistent ... or not.
The small particle ranges are pretty wide though. 24 equals 80 000 to 160 000 , 23 equals 40 000 to 80 000 ...
So MAYBE they are accurate ?
Or might it be that things don't work the way we suspect they do... ?
It's a bit perplexing, because some of the PCs posted by members here seem to follow the rated ISO filter efficiency pretty well as you've seen by some of my plots of that data. To me, that doesn't seem to just be a coincidence. Something is going on, but hard to know what at this point.
I suspect that you may well be correct here...
There's no reason beyond somw anomaly that a PC shouldn't be better with a more efficient filter. All the SAE papers that study filtration show a very good correlation between PC oil cleanliness and filter efficiency.
Some of the PC data off this site that I've plotted shows that expected correlation - even the Microguard showed better PC below the 15μ point like you'd expect. When filters rated at 50% @ 20μ or 99% @ 40μ have the same PC as filters rated at 99% @ 20μ then something is skewing the correlation. Maybe something is amiss at Blackstone. How is that test equipment calibrated, and how often?
Call them or e-mail them and ask they will tell you.
I don't think Blackstone is what is askew... I agree that something might be askew and if so it would be interesting to figure out what it is. It also could be that a lab created correlation does not necessarily translate into a real world correlation.
I see no reason why it wouldn't. It doesn't make sense that two filters on opposite ends of the filtering efficiency spectrum would give the same oil PC/cleanliness measurement. You've seen the SAE study plots in controlled tests I've posted before, and the oil PC data followed the filter rated efficiency very well. We may never know what the real reason is.
I am new to this PC and don't see very much to compare the results to, but what are the chances that the 2011 Amsoil filter test is not accurate (or no longer accurate) and the Toyota OEM filter is better than most people report? Or am I not tracking correctly on the ISO code I got?
I've seen plenty of pc that show filters rated highly effective bay SAE not look better than a typical cellulose filter. It's probably got to do with multiple passes.
I no longer believe there is much benefit to spending extra on so called highly efficient filters.
High capacity filters can, ofcourse, be worth the extra cost but only if they are used for extended hours or miles. If I buy a M1 oil filter rated for 20k miles and I keep it in use for 20k mile or the equivalent in hours then that's money well spent. If a guy has an application that doesn't allow him to safely go the full distance or he just don't want to then to then it was a bad purchase and benefits him nothing.
It's possible the Toyota Denso filter is better than 51% @ 20u per the independent ISO 4548-12 testing Amsoil published back in 2011.
But here is some PC data I posted from the UOA forum on BITOG, and this is how I'd expect the data to plot out showing a good correlation between the ISO 4548-12 rated efficiency and the PC data.
My theory on why some filters show a bad PC (DuckRyder's XG7317) vs their efficiency rating is because they are probably leaking somewhere past the media due to manufacturing issues (not design), or the methodology of the oil collection and/or test accuracy and repeatability is bad - that's the only things that makes sense. Other Ultras and similar high efficiency filters have shown good PC correlation with their rated efficiency. Open the uploaded PDF file for a better view of the plots.
If I were to take a sample from the current YZZD3 filter I have on our RX330 at 2,500 miles, swap to a Tough Guard and run it for 2,500 miles, send in a sample and get a PC on each, that should be a good apples-to-apples comparison?
The other option is to remove the current filter (it only has about 500 miles on it), install a TG and run it for about 5,000 miles (to make an apples-to-apples for the test I posted above) and then get a PC.
Trying to decide which to implement.
I would think running the TG for the whole 5000 miles on the same engine would be a better comparison. Swapping to a TG now with only 500 miles on the oil and running it to 5000 miles shouldn't skew the results.
How are you taking the UOA samples?
Unless the filter design has changed since the test I sort of doubt it.
My problem with this (which you well know) is that if you only plot the data that supports your hypothesis the data will always support your hypothesis.
We've been over all this as well. There were no signs of defects in the filter. No one mentioned seeing any either when it was posted. I believe it would be MUCH more likely that sampling methodology would create a low PC vs high. I did confirming follow up PC on both the Ultra and Hamp. My data is clean, it is at least as good as any other data here. Still, it is only 2 filters on one car, so it only tells us how those particular filters performed on that car.
In order to prove or disprove any correlation we would need much more data collected using a consistent procedure.
When I originally embarked on the PC counts part of what I wanted to try to figure out was if filters really do get more efficient as miles pass, which seems to be a common belief. You could actually do both, run your Toyota filter for 2500 miles take a sample, change the filter to a TG and sample it at 2500 then again at 5000. The oil should have no problem going 7500.
After going back and looking at your UOA, I notice the Lexus has high mileage, as does the Civic. This is another thing thats been in the back of my head,,, The filter can't catch what the engine doesn't produce. It may be that PC counts from newer engines are going to be inherently lower than those from higher mileage engines... All variable that need to be considered.
I've also shown plots of your XGs that deviate from the expected correlation.
IMO, there's some unkown factor(s) why some PCs deviate from the expected general PC data trend (ie, better filtration results in cleaner oil). It's not a big stretch to believe that a filter rated at 99% @ 20μ should keep oil cleaner than a filter rated at 50% @ 20μ. If the data doesn't show that trend, then the question needs to be asked why not. SAE filtration studies (under more controlled conditions than BITOG data) show that expected correlation.
Your comment about PC tests on low vs high mileage engines is something to ponder. And I agree that doing PC tests on the same engine and oil for the same miles driven, and only changing what filter is used would be a more controlled test.
I have Fumoto valves on all of our vehicles. I let the oil drain for about 20-30 seconds, take my sample and then resume draining to my recycle container.
I will grab a TG tomorrow and put it on.... I am wasting a perfectly good Denso unit, but am really curious about the results.
If the Denso only has 500 miles on it you could remove and bag it with base up (to keep it from leaking and keep it clean), and reuse it on the next oil change. The base gasket should still be fine with only 500 miles on it.
