Home
Fram ultra
Posted By: Spitter
Fram ultra - 06/04/18 06:12 PM
Would the really low micron rating of the fram ultra not hurt oil flow? Any trouble with these clogging before 10k?
Posted By: kschachn
Re: Fram ultra - 06/04/18 06:14 PM
No and no.
Posted By: Pajero
Re: Fram ultra - 06/04/18 06:19 PM
Go direct with Motorking (Fram Rep). He will give you the psi ratings for your application.
Respectfully,
Pajero!
Posted By: maxdustington
Re: Fram ultra - 06/04/18 06:25 PM
I have seen it mentioned that the Ultra can cause start up rattle, but that seems to be application specific.
What about the Fram Racing version of the Ultra?
Posted By: WhizkidTN
Re: Fram ultra - 06/04/18 06:46 PM
FWIW: I've used the FRAM Ultra in my car applications (two different cars) for a good while now. No start-up rattles.
Posted By: doolah02
Re: Fram ultra - 06/04/18 07:31 PM
I get start up rattle in my'01 Sport Trac with the Fram Ultra, but with the Mobil 1 filter
I get almost no rattle.
Posted By: JLTD
Re: Fram ultra - 06/04/18 08:22 PM
No and no.
/thread
Posted By: LeakySeals
Re: Fram ultra - 06/04/18 09:54 PM
Agree its app specific. It makes my 6.0 lq9 Escalade tick and slap at startup more noticeably than lesser efficient filters. So I don't use the Ultra anymore on that engine. Use the TG.
Posted By: LotI
Re: Fram ultra - 06/04/18 10:19 PM
Huh? Arenít they both 99% filters?
Posted By: OVERKILL
Re: Fram ultra - 06/04/18 10:29 PM
The XG probably outflows the TG...
Posted By: Spitter
Re: Fram ultra - 06/04/18 10:33 PM
I wish i had the lq9. May be a swap for a future date.
Posted By: ZeeOSix
Re: Fram ultra - 06/04/18 11:20 PM
The old internet falsehood that high efficiency means high delta-p and flow restriction will never die. It's full synthetic media that allows High flow, high efficient and high holding capacity.
Posted By: ZeeOSix
Re: Fram ultra - 06/04/18 11:53 PM
Start up rattle is typically a leaking ADBV ... not "flow restriction" of the filter.
Posted By: ZeeOSix
Re: Fram ultra - 06/04/18 11:54 PM
Yep, that's why start up rattle isn't caused by "flow restriction" ... but a bad ADBV instead.
Posted By: OVERKILL
Re: Fram ultra - 06/04/18 11:58 PM
thumbsup
Posted By: nike360baller
Re: Fram ultra - 06/05/18 12:40 AM
I was getting a grind on P66 Honda OEM oil 0w-20 and stock A02 filter. I changed to Idemitsu 0w-20 and Fram Tough guard and I yielded a 99.9% improvement. Needles to say and "meanwhile", I get a case of free filters from FRAM and I got an ultra on deck. I will make sure the tech is vigilant about any start-up noise during oil install.
Posted By: kschachn
Re: Fram ultra - 06/05/18 02:08 AM
Sure.
Keep posting nonsense Mike, or whatever your name of the month is. How many have you gotten banned so far?
Re: Fram ultra - 06/05/18 03:04 PM
thumbsup
I thought so too. Why I stubbornly went back to the Ultra 3 different times to make sure it wasn't just a one-off issue. Same results. More noise at startup.. lifter ticks, some slap, etc. Last time I removed the Ultra the following day to check the ADBV. Had at least 1/2 qt before the filter after sitting overnight. So I'm done with the Ultra on this engine.
Also noted this is a recent problem. Used the Ultra for a couple years on this engine. Never noticed anything before.
Posted By: Triple_Se7en
Re: Fram ultra - 06/05/18 03:10 PM
I've had the same Ultra issues LeakySeals. Maybe you haven't noticed it yet, but check to see iof that engine is running smoother at idle, without that Ultra on. Mine does and witnessing that shocked me. Never would have thunk a standing idle could get affected by a very highly efficient oil filter. Could be why Fram is making changes (ie... bypass pressure settings for instance) regarding their Ultras on some GM vehicles.
I still like the new basic Fram EGs. Have that on my wife's 2003 GM Malibu...... no issues.
Posted By: OVERKILL
Re: Fram ultra - 06/05/18 04:07 PM
Easy test: Try a different brand of glass media filter like the AMSOIL EaO, Royal Purple, WIX...etc. It may be an ADBV design on the Ultra that simply does not seal well in your application period. These other filters have a different design in that department which may make a difference.
The Ford Modulars were notoriously sensitive to ADBV sealing and I personally, with a glass media filter (Fleetguard Stratapore) experienced significant start-up noise that was mitigated by using a different one (AMSOIL EaO).
Posted By: Pajero
Re: Fram ultra - 06/19/18 05:48 AM
Indeed!
Respectfully,
Pajero!
© 2019 Bob Is The Oil Guy
