Motorcraft FL500S and AcDelco PF63E
Pennywise has control ...
Originally Posted By: BlueOvalFitter
PF63E-22 PSI
FL-500S-8 PSI
BOF, where did you find the bypass setting info on the FL-500S?
PF63E-22 PSI
FL-500S-8 PSI
I GOOGLED "FL-500S PSI" and a few Mustang and other forum websites came up. I read through most of the posts and all of the responses were the same when asked the PSI Q?, 8 PSI.
Originally Posted By: WellOiled
ZeeOSix - I went looking for the bypass setting and found the efficiency spec instead.
FL820S specs
FL500S specs
80% for particles 20 microns or larger.
Weird that Ford/Motorcraft doesn't list the bypass valve setting, but others on chat boards are saying it's 8 PSI ... ?
8 PSI seems pretty low to me.
FL820S specs
FL500S specs
Z06, sometimes, when I'm looking for certain specs. on an oil filter, I go to AUTZONE's website, enter the filter part number, and it gives the specs. on said filter. I know it's not scientific, but AZ has to be getting their info. from somewhere legitimate.
FL820S specs
FL500S specs
Maybe that is all that is needed at application flow rates.
I could not find anything official on the bypass settings in general.
No info about Motorcraft oil filter's bypass setting on AutoZone
- LINK
Nothing on the O'Reilly website either - LINK
The PH10575 is 9 to 15 PSI. The way I would interpret this is begins to open at 9 and fully open at 15.
I'd interpret that to mean it starts to open at 12, plus or minus 3. "Fully open" would imply a high bypass flow rate (in addition to the flow through the media).
That's how I'd read that also. It will take more PSI to compress the spring from closed to fully open.
- LINK
I did state SOMETIMES.
Yeah, I know. I'm just trying to track down the official source of the 8 PSI spec.
I did some searching on this too recently and found the same info and links that have been listed so far, but nothing that looked it was from any official data. 8psi does seem pretty low, but if we’re speculating that the 9-15psi range listed for other filters is the starting point (9psi) and the pressure needed to be completely open (15psi), then maybe MC’s 8psi is just the point at which the valve starts to open. If that’s the case, then there really isn’t much difference. Heck, I bet there’s more than 1psi variability filter to filter of the same design.
... That's how I'd read that also. It will take more PSI to compress the spring from closed to fully open.
It's unlikely to ever be fully open, except in extreme situations.
Of course.
