Home
List an oil Additive you'd use / No Comments
Posted By: SuperDave456
List an oil Additive you'd use / No Comments - 08/30/16 07:33 AM
I Thought it'd be fun to list Oil Additives you trust and would use or have used.
No other comments please.
I'll go first.
Lubro Moly Engine Oil Saver
Posted By: Kibitoshin
Re: List an oil Additive you'd use / No Comments - 08/30/16 07:43 AM
Lubro Moly MoS2 and Engine Flush
Redline ZDDP additive
Posted By: SR5
Re: List an oil Additive you'd use / No Comments - 08/30/16 08:04 AM
Liqui-Moly Friction Reducer - (MoS2) Molybdenum Disulphide oil additive
Posted By: Farmer
Re: List an oil Additive you'd use / No Comments - 08/30/16 08:33 AM
Liqui Moly Anti Friction
Liqui Moly Motor Oil Saver
Liqui Moly Pro Line Engine Flush
ATP-205
Posted By: FowVay
Re: List an oil Additive you'd use / No Comments - 08/30/16 08:54 AM
Liqui-Moly MOS2
Liqui-Moly motor oil saver
Schaeffer Moly EP
Camguard (for aircraft engines)
BG MOS
I'm sure there are others... smile
Posted By: SteveSRT8
Re: List an oil Additive you'd use / No Comments - 08/30/16 09:27 AM
Kreen is the only additive we ever use, and sparingly at that...
Posted By: stro_cruiser
Re: List an oil Additive you'd use / No Comments - 08/30/16 09:58 AM
Bio/Tech Engine Oil Protectant with LXE® Technology
Posted By: BobaLouie
Re: List an oil Additive you'd use / No Comments - 08/30/16 10:30 AM
Lubegard 60902 Automatic Transmission Fluid Protectant with LXE® Technology
ATP AT-205 Re-Seal
Posted By: Pop_Rivit
Re: List an oil Additive you'd use / No Comments - 08/30/16 10:38 AM
Whatever additives the oil companies already put in the bottle. Beyond that, I don't waste my money on any of them.
Posted By: Garak
Re: List an oil Additive you'd use / No Comments - 08/30/16 10:43 AM
Nothing, ever, outside of a ZDDP additive during break in on a flat tappet rebuild.
Posted By: UltrafanUK
Re: List an oil Additive you'd use / No Comments - 08/30/16 10:51 AM
Liqui Moly oil flush and Ceratec are the main additives I have used in my old TDI. If I had any oil leaks that were beyond economic repair, I would also used Motor Oil Saver stop leak additive.
If you are going to use oil additives, it is a good idea to stick to the larger engine oil companies and steer well clear of the back street snake oil mixers.
Posted By: rooflessVW
Re: List an oil Additive you'd use / No Comments - 08/30/16 10:59 AM
Liqui Moly:
Motor Oil Saver
MoS2
Ceratec
Others:
BG MOA
Lubegard BioTech
There are others, but you only asked about engine oil.
Posted By: WobblyElvis
Re: List an oil Additive you'd use / No Comments - 08/30/16 11:34 AM
+1
Posted By: Fsharp
Re: List an oil Additive you'd use / No Comments - 08/30/16 11:52 AM
Lubegard Bio-Tech
Liquimoly MOS2
MMO
Restoregrin
Posted By: FowVay
Re: List an oil Additive you'd use / No Comments - 08/30/16 12:38 PM
What's that one with the teflon? I can't remember the name but they advertise the slipperiest surface on planet earth.
Also, I meant BG MOA in my previous post. I accidentally put MOS...
Posted By: Marco620
Re: List an oil Additive you'd use / No Comments - 08/30/16 12:48 PM
Liquimoly Mos2,Motor Oil Saver, AND Ceratec
Lubegard Biotech
Posted By: AirgunSavant
Re: List an oil Additive you'd use / No Comments - 08/30/16 12:57 PM
Tufoil
Posted By: vintageant
Re: List an oil Additive you'd use / No Comments - 08/30/16 01:21 PM
Liqui Moly MoS2 for the '25 & '70
Liqui Moly MoS2 plus Motor Oil Saver for the '37 (she's thirsty)
Used Ceretec once in the '70, but Liqui Moly advised it's formulated for newer engines.
Posted By: gfh77665
Re: List an oil Additive you'd use / No Comments - 08/30/16 01:51 PM
Restore.
Posted By: Leo99
Re: List an oil Additive you'd use / No Comments - 08/30/16 02:02 PM
Prolong
Posted By: SF0059
Re: List an oil Additive you'd use / No Comments - 08/30/16 02:19 PM
Liqui Moly:
Motor Oil Saver (this stuff is like magic if you are losing oil)
MoS2
Ceratec
Posted By: 4WD
Re: List an oil Additive you'd use / No Comments - 08/30/16 02:28 PM
Extra adds in Mobil 1 HM at 50/50
Posted By: surfstar
Re: List an oil Additive you'd use / No Comments - 08/30/16 02:37 PM
LC20
Posted By: kr_bitog
Re: List an oil Additive you'd use / No Comments - 08/30/16 02:46 PM
Liquimoly MoS2, Suprotec High Mileage
Posted By: Yah-Tah-Hey
Re: List an oil Additive you'd use / No Comments - 08/30/16 03:05 PM
Posted By: Farmer
Re: List an oil Additive you'd use / No Comments - 08/30/16 03:36 PM
I forgot two more
MMO
Lubegard Red
Posted By: ShotGun429
Re: List an oil Additive you'd use / No Comments - 08/30/16 04:02 PM
STP
Posted By: ARCOgraphite
Re: List an oil Additive you'd use / No Comments - 08/30/16 04:15 PM
Never tried but might try iso 68 di-ester refrigerant compressor lube if I had a batch of oil that "needed" amendment.
Posted By: SaturnIonVue
Re: List an oil Additive you'd use / No Comments - 08/30/16 04:44 PM
None
Posted By: HTSS_TR
Re: List an oil Additive you'd use / No Comments - 09/01/16 12:51 AM
Looks like Lubro Moly MoS2 is most popular.
Posted By: OldEuroCarLover
Re: List an oil Additive you'd use / No Comments - 09/01/16 01:58 AM
I'm about to use Liqui-Moly MoS2 when I change the oil. Based on the responses here, it looks like I'm not a complete idiot. grin
Posted By: Jetronic
Re: List an oil Additive you'd use / No Comments - 09/01/16 08:22 AM
Or not the only idiot, of course... just pointing that out, I take no sides wink
Posted By: Gregg924dg
Re: List an oil Additive you'd use / No Comments - 09/01/16 10:11 PM
Tufoil
______________
2015 Toyota Sienna
2007 Honda CRV
1995 BMW 325ic...her toy
Re: List an oil Additive you'd use / No Comments - 09/01/16 11:16 PM
Ceratec is better, as it contains both Moly AND Boron Nitride in a hexagonal form. I suspect the Moly is included because many non major brand or cheap conventional base oils don't include it.
Liqui Moly are the best oil additive company around, although they do not make additives for auto boxes and there are other companies in the US that make good fuel additives.
Posted By: Run
Re: List an oil Additive you'd use / No Comments - 09/02/16 03:50 AM
MOS
Posted By: EchoTech1945
Re: List an oil Additive you'd use / No Comments - 09/02/16 07:08 AM
MolySlip E ( MolySlip E )
Posted By: gman2304
Re: List an oil Additive you'd use / No Comments - 09/02/16 03:31 PM
Mos2
Posted By: SHOZ
Re: List an oil Additive you'd use / No Comments - 09/02/16 03:43 PM
Auto-RX
Posted By: m37charlie
Re: List an oil Additive you'd use / No Comments - 09/04/16 08:50 PM
Redline Breakin additive: 20500ppm Zn, 17000ppm P, 20500ppm Ca.
Charlie
Posted By: southernjeeper
Re: List an oil Additive you'd use / No Comments - 09/05/16 10:42 PM
Switching to liquid moly mos next oil change!
Probably no more Lucas syn
Posted By: Ohle_Manezzini
Re: List an oil Additive you'd use / No Comments - 09/06/16 01:03 AM
STP, MOS2, Graphite, Zmax, Jhonsons baby oil + Engine flush...
Posted By: Nickdfresh
Re: List an oil Additive you'd use / No Comments - 09/23/16 02:24 PM
Quality motor oil... smile
But in a dirty, sludged engine on a beater: Rislone Engine Treatment...
Possibly a Liqui-moly product, but not likely.
I may use STP as a thickener if I change oil in an older car and it starts burning...
Posted By: Ducked
Re: List an oil Additive you'd use / No Comments - 09/23/16 02:56 PM
Bit of British culture for you.
While waiting for a train in a WH Smith's newsagent I found a "humour" book in a bargain bin. Titled something like "The Arthur Daley Book of Scams"
Arthur Daley was a British TV dodgy businessman character, with connections to the motor trade.
Flicked through it. The scams I looked at were plausible and some of them I'd seen in action in real life. Wish I'd bought the book.
In Arthurs bio, he was credited with inventing the nylon-shirt-in-the-gearbox trick. If I have another car with a failing gearbox (I once had a Marina gearbox which was mostly filings but continued to shift smoothly) I'll probably try it.
Posted By: DriveHard
Re: List an oil Additive you'd use / No Comments - 09/23/16 05:33 PM
Mos2
Posted By: deven
Re: List an oil Additive you'd use / No Comments - 10/16/16 02:42 PM
Originally Posted By: Gregg924dg
Tufoil
+1
Posted By: Michael_P
Re: List an oil Additive you'd use / No Comments - 10/22/16 10:10 PM
What about substituting a quart of regular oil with racing oil? For instance, if one were to use 4 or 5 qts of M1 0W30 with one quart of M1 0W30 racing oil, could this properly boost additives? Its about double the cost of a regular oil, so cheaper than many additives.
M1 0W30 VOA:
Re: List an oil Additive you'd use / No Comments - 10/22/16 11:29 PM
Wow, that's a bunch of Moly!
Re: List an oil Additive you'd use / No Comments - 10/23/16 07:16 AM
OMG, that's more Moly than Redline use!
Re: List an oil Additive you'd use / No Comments - 10/23/16 01:57 PM
Michael_P - great idea, thanks! $6.69 a quart at my local AAP
Posted By: Jonzobot
Re: List an oil Additive you'd use / No Comments - 10/23/16 06:19 PM
I'm surprised not many use LC20 given its popularity on this forum a number of years back. I've just ordered myself some for a piston soak, but other than that I don't add anything.
Posted By: Virtus_Probi
Re: List an oil Additive you'd use / No Comments - 10/24/16 12:11 PM
LM MoS2
Re: List an oil Additive you'd use / No Comments - 10/24/16 09:14 PM
Added liquimoly last week.
Posted By: mctmatt
Re: List an oil Additive you'd use / No Comments - 10/25/16 10:08 AM
Just added LM Mo52 to two of my vehicles when I changed the oil this past week.
Re: List an oil Additive you'd use / No Comments - 10/26/16 02:54 PM
Graphited motor oil, cleaned my engine.
Look the dirt that came from between 2 pleats of paper, in a ocod.
That's smelly oxidated oil, plus sludge...
Posted By: deven
Re: List an oil Additive you'd use / No Comments - 10/26/16 04:52 PM
You just wanted to give us the dirty bird salute lol!
Re: List an oil Additive you'd use / No Comments - 10/26/16 07:35 PM
crackmeup LOL
Re: List an oil Additive you'd use / No Comments - 10/27/16 03:44 PM
Strewth, I only just noticed the high Zinc, so if your engine does not have a CAT or DPF, this Mob 0w30 could indeed be used to boost the Moly and Zinc in some El-Cheapo dinosaur oil.
Re: List an oil Additive you'd use / No Comments - 10/28/16 04:05 PM
Would Valvoline VR1 Racing Oil 20W50 have the same high Moly and Zinc as the Mob 0W30?
Posted By: 05LGTLtd
Re: List an oil Additive you'd use / No Comments - 10/29/16 03:39 PM
LM Motor Oil Saver
MMO (final few hundred miles before oil change for cleaning)
Risalone
Posted By: SHOZ
Re: List an oil Additive you'd use / No Comments - 10/29/16 03:54 PM
I used some solid waxy like molybdenum once. It came from the leftovers in a barrel of MolyKote. There was always some that settled out at the bottom of the barrel.
Re: List an oil Additive you'd use / No Comments - 10/29/16 11:27 PM
Valvoline 20W50 VR1 Racing Oil
Re: List an oil Additive you'd use / No Comments - 10/30/16 02:58 PM
Thank Michael_P!
Zero Moly and not particularly high Phosphorus or Zinc.
Posted By: Bamaro
Re: List an oil Additive you'd use / No Comments - 10/31/16 12:55 PM
Nothing on my newer cars, ZDDP additive on my 70
Re: List an oil Additive you'd use / No Comments - 11/02/16 12:14 AM
It's just a cheap thick oil that will give your battery and starter a real hard time in winter.
No Moly, No Boron, low detergents, so no way would I use it in my old TDI engine. The TBN is low for a Ca detergents only oil, so it is not going to be too good for a long OCI.
Posted By: deven
Re: List an oil Additive you'd use / No Comments - 11/02/16 04:23 PM
BG Extended Life MOA
Posted By: Bgallagher
Re: List an oil Additive you'd use / No Comments - 11/21/16 06:17 PM
ATP AT-205 Re-Seal
+1
Posted By: thunderchild
Re: List an oil Additive you'd use / No Comments - 11/22/16 06:30 PM
Kreen by KANO Labs. had a bad tick in my 04 5.3 Tahoe. Kreened it and 4 years an no ticking return.
Posted By: Red91
Re: List an oil Additive you'd use / No Comments - 11/24/16 04:56 PM
Liqui Moly MoS2. I haven't tried the motor oil saver.
Posted By: NycDito
Re: List an oil Additive you'd use / No Comments - 12/02/16 07:41 PM
Lubro Moly engine flush, Mos2 and or Ceratec.
Re: List an oil Additive you'd use / No Comments - 12/03/16 12:20 AM
Liqui Moly (Lubro Moly was some old name only used in the US) Ceratec, Motor Oil Saver, Diesel Purge and their latest idle flush.
Posted By: SnowDrifter
Re: List an oil Additive you'd use / No Comments - 12/18/16 12:45 AM
LM MoS2
LM Ceratec
Seafoam
ZddPlus
LM MoS2
LM Ceratec
Seafoam
ZddPlus
Posted By: Bighorn2500
Re: List an oil Additive you'd use / No Comments - 12/28/16 12:19 AM
Lucas ZDDP additive
Posted By: Nenad16
Re: List an oil Additive you'd use / No Comments - 01/01/17 10:51 AM
Anything Lubegard
Posted By: 55Test
Re: List an oil Additive you'd use / No Comments - 01/02/17 09:26 PM
Bardahl B2 in an old engine, B1 in a newer engine
Posted By: asiancivicmaniac
Re: List an oil Additive you'd use / No Comments - 01/19/17 10:40 PM
Just put a bottle of Ceratec in my 02 Maxima.
Contemplating getting another bottle or Lubegard Biotech for my '16 FiST.
Posted By: Ducked
Re: List an oil Additive you'd use / No Comments - 01/19/17 11:12 PM
Straight 40. As top-up in 15/40.
Posted By: MinamiKotaro
Re: List an oil Additive you'd use / No Comments - 01/19/17 11:22 PM
MMO. Ceratec.
Posted By: CourierDriver
Re: List an oil Additive you'd use / No Comments - 01/25/17 10:53 PM
I have stopped doing the oil additive I guess, but when I did, it was usually MMO....now days, I just add synthetic 2 cycle to the gas for cleaning and lubing,,,works for me
Posted By: barkingspider
Re: List an oil Additive you'd use / No Comments - 01/27/17 12:07 AM
Motor medic 5 min flush
Mmo
Amsoil flush
Berrymans
Posted By: ebr1190rx
Re: List an oil Additive you'd use / No Comments - 02/22/17 03:32 PM
Kreen and lubegard biotech
Posted By: MolaKule
Re: List an oil Additive you'd use / No Comments - 02/22/17 07:56 PM
I'll go first.
A question that would be more informative would be:
What additive do you use and for what problem and do you have any proof it worked?
Posted By: Clevy
Re: List an oil Additive you'd use / No Comments - 02/22/17 08:58 PM
I'll go first.
Ha.
Nothing changes around here eh.
Posted By: SatinSilver
Re: List an oil Additive you'd use / No Comments - 02/22/17 09:01 PM
Hey welcome back Clevy. This is your first post in 10 months. There's been a few threads started about you along the lines of, Where's Clevy. smile
Clevy Thread
Another One
Posted By: MrQuackers
Re: List an oil Additive you'd use / No Comments - 02/23/17 12:05 AM
^Glad to see you're alive and kicking smile
Posted By: Koz1
Re: List an oil Additive you'd use / No Comments - 03/08/17 03:40 PM
Lubegard. http://www.lubegard.com
Posted By: boxcartommie22
Re: List an oil Additive you'd use / No Comments - 03/09/17 12:28 AM
lubegard, archoil, hotshots, bg, red line,
Posted By: KCJeep
Re: List an oil Additive you'd use / No Comments - 03/17/17 11:17 PM
In order of frequency of actual use.
MMO
MoS2
Rislone
STP blue bottle
Restore
Re: List an oil Additive you'd use / No Comments - 03/17/17 11:21 PM
MMO
What amount do you use and for how many miles? I know what the bottle says but from the reports on here I see users putting it in the oil for for only a few hundred miles before an oil change. Do you put in the fuel as well? It's certainly reasonably priced.
Posted By: AmoryBlaine
Re: List an oil Additive you'd use / No Comments - 03/17/17 11:47 PM
Used to add what was a half qt of an oil thickener from wal mart. Haven't seen it in a long time.
Posted By: harryberry
Re: List an oil Additive you'd use / No Comments - 03/22/17 10:50 PM
The Everglide EGS oil additive.
Its formula is nano-based (Moly-Graphene) and has been very effective in increasing my MPG. Less noise and far better acceleration.
Posted By: PabloZ
Re: List an oil Additive you'd use / No Comments - 03/23/17 10:28 AM
Ceramizer (ceramic oil additive) in Megane 1.9 dci
Posted By: 2KBMW
Re: List an oil Additive you'd use / No Comments - 03/23/17 11:40 PM
Rislone
Posted By: Crashbox
Re: List an oil Additive you'd use / No Comments - 03/26/17 05:58 AM
LC-20.
Auto-Rx about once every 50K miles nowadays.
Henkel SLA-1286 (MoS2): a VERY small amount once in a while.
Posted By: panthermike
Re: List an oil Additive you'd use / No Comments - 03/27/17 07:23 PM
-LG Biotech
-MMO once a while
Posted By: jakewells
Re: List an oil Additive you'd use / No Comments - 04/07/17 07:00 AM
lucas laugh
Posted By: Malo83
Re: List an oil Additive you'd use / No Comments - 04/07/17 07:05 PM
STP tongue2
Posted By: ARB1977
Re: List an oil Additive you'd use / No Comments - 04/08/17 02:16 PM
I've got 1000 miles so far on biotech. So far so good.
Posted By: OPR4H
Re: List an oil Additive you'd use / No Comments - 04/09/17 02:27 AM
Winns laugh
Posted By: newtoncd8
Re: List an oil Additive you'd use / No Comments - 04/09/17 03:15 AM
Tufoil
+1
+2
Posted By: Piston_slap
Re: List an oil Additive you'd use / No Comments - 04/13/17 01:38 PM
Madam Charlemagne's "Black Drought Engine Snot" with "Bayou Friction Divider"
Posted By: deven
Re: List an oil Additive you'd use / No Comments - 07/18/17 04:26 PM
BG MOA
Posted By: Speedbird001
Re: List an oil Additive you'd use / No Comments - 07/19/17 05:28 AM
STP a little when I was younger
BG MOA like clockwork from ~2000-2010
nothing now
Posted By: ltslimjim
Re: List an oil Additive you'd use / No Comments - 07/20/17 09:51 PM
Lubegard products
Lubro Moly (Liqui Moly) products
Red Line products
Amsoil products
This is for oil, fuel, and ATF additives or replacement lubes.
Posted By: Oil_Flunky
Re: List an oil Additive you'd use / No Comments - 07/20/17 10:56 PM
Internal engine cleaners:
Rislone
LC20
Kreen
Neutra
Posted By: blupupher
Re: List an oil Additive you'd use / No Comments - 07/21/17 02:16 AM
Auto-Rx
Posted By: Triton_330
Re: List an oil Additive you'd use / No Comments - 08/02/17 02:48 AM
Oil Additives:
LM MoS2
Rislone
MMO
STP (before BITOG)
Seafoam (before BITOG, only as 10 min flush)
Gas Additives:
Redline Sl-1
Chevron Techron
Gumout
Berryman B-12
Stabil 360
MMO
Mag 1 Octane Booster (used in my motorcycle)
STP Octane Booster (used in my motorcycle)
If by "auto box" you are referring to transmissions, they do have an ATF additive (for use in auto trans and in power steering pump) - https://www.amazon.com/gp/product/B004X63XVU/
Posted By: MarkusG
Re: List an oil Additive you'd use / No Comments - 08/08/17 12:43 PM
Molyslip E for all my engines ( daily driver,race car,truck,lawnmower)
Molyslip G MTS for the gearbox on my sports car
Molyslip ATS for the automatic transmission in my van
smile
Posted By: demarpaint
Re: List an oil Additive you'd use / No Comments - 08/08/17 03:46 PM
I've been using Rislone ZDDP additive in my power washer, and mower this season.
Posted By: speedyswede
Re: List an oil Additive you'd use / No Comments - 08/10/17 04:49 PM
Lubegard Biotech Engine Protectant
LiquiMoly Motor Oil Saver
Re: List an oil Additive you'd use / No Comments - 08/11/17 08:42 PM
Lucas ZDDP additive
Posted By: ChevyMan93
Re: List an oil Additive you'd use / No Comments - 08/24/17 11:35 PM
Kreen is amazing at cleaning up sludge and quieting things down. MMO is awesome in oil for a slower clean, and great in fuel for a UCL and fuel system cleaner.
Posted By: spasm3
Re: List an oil Additive you'd use / No Comments - 08/25/17 12:21 AM
I have used kreen in an older car for cleaning. I go back and forth about mos2. I worry about mos2 collecting in my pan and engine valleys, but i like the idea.
I would like to know what form of moly, is in the idemitsu moly oil that mazda sells.
Posted By: SHOZ
Re: List an oil Additive you'd use / No Comments - 08/25/17 02:04 AM
Ceratec in my gearbox.
Posted By: beanoil
Re: List an oil Additive you'd use / No Comments - 09/15/17 01:02 PM
In order of frequency:
LubeGard Bio-Tech
Schaeffer 132
Posted By: thorromig
Re: List an oil Additive you'd use / No Comments - 10/11/17 04:14 PM
Liqui Moly MOS2
Lube Guard Red
Posted By: ZZman
Re: List an oil Additive you'd use / No Comments - 10/12/17 01:51 PM
Engine flush, Rislone and MMO
Re: List an oil Additive you'd use / No Comments - 10/12/17 07:00 PM
Lubeguard Red for the trannys -- oops -- my bad on this topic.
Posted By: StevieC
Re: List an oil Additive you'd use / No Comments - 10/13/17 03:02 AM
Amsoil Flush then straight engine oil.
Posted By: gfh77665
Re: List an oil Additive you'd use / No Comments - 10/15/17 10:31 AM
Yes. I know its taking "their word" for it, but I tend to believe this:
https://www.restoreusa.com/compression-tests
Posted By: BrocLuno
Re: List an oil Additive you'd use / No Comments - 10/21/17 01:46 AM
BG 109 & MMO laugh
Posted By: Olinskis
Re: List an oil Additive you'd use / No Comments - 06/06/18 10:20 PM
Wanted to bring this one back as I missed it.
Me:
LC20 & FP+
Brother:
Seafoam and MMO
Dad:
Motorkote
...we argue all the time crazy
Posted By: TheLawnRanger
Re: List an oil Additive you'd use / No Comments - 06/06/18 10:23 PM
None
Re: List an oil Additive you'd use / No Comments - 06/07/18 05:23 AM
shaeffers 132.
Posted By: littleant
Re: List an oil Additive you'd use / No Comments - 06/09/18 12:28 PM
Lubegard Red Transmission
Posted By: Brigadier
Re: List an oil Additive you'd use / No Comments - 06/10/18 03:04 AM
Lubegard
Re: List an oil Additive you'd use / No Comments - 06/10/18 09:59 AM
Originally Posted By: Brigadier
Lubegard
Good stuff.
Posted By: Brons2
Re: List an oil Additive you'd use / No Comments - 07/20/18 09:19 PM
Unicorn sweat.
Use it in my gas and my oil.
Posted By: SHOZ
Re: List an oil Additive you'd use / No Comments - 07/20/18 09:24 PM
I put CeraTec in both my engines
Posted By: urrlord
Re: List an oil Additive you'd use / No Comments - 07/21/18 01:53 AM
Running Rislone Nano in my 2001 Tribute v6.I have had it in about 400 miles so far.The engine is a lot quieter even when I put the pedal to it,this engine has always been a bit noisy.Until now.
Posted By: urrlord
Re: List an oil Additive you'd use / No Comments - 07/21/18 01:54 AM
When I feel like getting flamed I'll start a post on the Rislone Nano.Don't feel like it right now.
Posted By: js1956
Re: List an oil Additive you'd use / No Comments - 05/19/19 03:51 PM
2oz Hyper Lube
2oz Lubegard
every oil change (5,000 miles)
Posted By: drfeelgood
Re: List an oil Additive you'd use / No Comments - 05/19/19 06:03 PM
I'm with poster above, my 2 current faves Lubegard and hyperlube ZRA
Re: List an oil Additive you'd use / No Comments - 05/19/19 07:24 PM
Will be trying Nano my next change in a couple weeks, I would also use Rislone Engine Treatment as a flush/cleaner if necessary on a used car. Some of the claims they make, usage directions and marketing nonsense they spew are one thing - but their products do work as far as cleaning dirty engines, when needed.....
Posted By: ChrisD46
Re: List an oil Additive you'd use / No Comments - 05/20/19 12:33 AM
MMO : While I've used before , I believe SN+ D1 / Gen 2 oils are so good now that not much MMO can do for an engine.
Seafoam : I still use from time to time for 100 miles before an oil change .
Posted By: Ponchinizo
Re: List an oil Additive you'd use / No Comments - 05/20/19 04:32 PM
Lubegard and Liqui Moly MOS2.
Posted By: dailydriver
Re: List an oil Additive you'd use / No Comments - 05/20/19 09:49 PM
^^^The only ones I will ever use. wink thumbsup
Posted By: JAG
Re: List an oil Additive you'd use / No Comments - 05/21/19 02:00 AM
Hy-perlube ZRA polymer ester
Posted By: addyguy
Re: List an oil Additive you'd use / No Comments - 05/22/19 05:25 PM
As my user name suggests, used to be a huge fan of additives. Not as much these days, bc you can just change the oil for the price of a lot of them.
That said, I think some have real benfits - a moly additive like MolySlip or Liqui-moly has been shown to help quiet engines and reduce wear.
I think for engines that suffer from noise or low OP, STP blue-bottle is a long-proven additive that 'boosts' up the oil a bit w/o doing any harm.
Just put a 15oz bottle in with my oil change, and engine is a bit quieter, bit smoother, and starts a bit quicker from improved cylinder sealing.
For the small price, not a bad product.
Posted By: Brian553
Re: List an oil Additive you'd use / No Comments - 05/23/19 03:11 PM
Hy-perlube ZRA
Rislone Nano Prime
Lubegard products
Ceratech
ATP AT-205 Re-Seal
Bar's Leak 1010, 1040, 1420, and 1344
Posted By: ZraHamilton
Re: List an oil Additive you'd use / No Comments - 05/24/19 06:55 AM
Hy-perlube Zinc Replacement Polymer Ester
AT-205 Re-Seal (maybe)
MMO
Posted By: Jetsfan421
Re: List an oil Additive you'd use / No Comments - 05/25/19 06:08 PM
Lubegard products
TC-W3 in gas
Posted By: Diesel12
Re: List an oil Additive you'd use / No Comments - 05/28/19 04:53 PM
Motorkote or Tufoil. Only 2 ive used.
Posted By: WAYNERIDES
Re: List an oil Additive you'd use / No Comments - 06/07/19 03:48 PM
motorkote/ duralube
Posted By: red7404
Re: List an oil Additive you'd use / No Comments - 06/18/19 12:13 AM
i use. ZDDplus. but i would NEVER use but one type of additive at a time. I.E. DONT mix brands
Posted By: UG_Passat
Re: List an oil Additive you'd use / No Comments - 06/18/19 08:55 PM
Renewable Lube Bio-Synxtra Booster Pak
http://renewablelube.com/store/motor-oils?product_id=158
© 2019 Bob Is The Oil Guy
