Continued to follow the Blackstone recommendations and extended this one to 50K. Will be pushing towards 60K for the next OCI. This truck does a lot of pulling, but only occassionally is it at the rated limit. Overall pretty happy with the results, especially the PPM / mile trends on Iron.
Make/Model: GM Rear Differential
Vehicle: 2004 Chevy 2500HD
Code
OIL SVG 75w90 SVG 75w90 SVG 75w90 VAL Syn 75W90
MILES IN USE 50,662 40,069 39,780 29,976
MILES ON UNIT 236,861 186,199 146,130 106,350
SAMPLE TAKEN 4/29/19 11/24/15 7/3/13 10/20/11
MAKE UP OIL 0 0 0 0
ALUMINUM 1 2 0 1
CHROMIUM 0 1 0 1
IRON 104 87 59 189
COPPER 0 0 0 1
LEAD 1 0 0 0
TIN 0 0 0 2
MOLYBDENUM 0 0 0 0
NICKEL 2 2 2 6
MANGANESE 4 3 4 13
SILVER 0 0 0 0
TITANIUM 0 0 0 2
POTASSIUM 0 9 0 1
BORON 76 76 109 284
SILICON 27 46 12 5
SODIUM 3 2 3 15
CALCIUM 19 19 24 64
MAGNESIUM 4 5 0 3
PHOSPHORUS 876 894 926 2192
ZINC 15 10 14 37
BARIUM 0 0 0 1
CADMIUM 0
VANADIUM 0
ANTIMONY 0
LITHIUM 2
SUS @ 210F 81.3 86.9 73.1
Visc @ 100C 15.84 17.22 17.9 13.7
Flashpoint 410 430 375
Water % 0.0 0.0
Insolubles % 0.1 0.1 0.3
TAN 2.7 2.9 2.10
Oxidation 45
Nitration 4
Oil Analysis Vendor Comments:
Silicon dropped and the increased iron isn't surprising. It tends to track with oil use, and on a per-mile basis, this level is impressively low. For reference, universal averages show 9.1 ppm/1K miles while this differential produced just 2.05 ppm/1K miles during this run. Other metals look good too, showing no mechanical problems. The viscosity was the only mark, reading just slightly thick for 75W90 oil, which isn't a problem at all. Clearly, internal parts didn't seem to notice. The TAN shows mild acidity at 2.7. Go ahead and try 60K miles or so next time. Nice!
Code
MAKE UP OIL 0 0 0 0
ALUMINUM 1 2 0 1
CHROMIUM 0 1 0 1
IRON 104 87 59 189
COPPER 0 0 0 1
LEAD 1 0 0 0
TIN 0 0 0 2
MOLYBDENUM 0 0 0 0
NICKEL 2 2 2 6
MANGANESE 4 3 4 13
SILVER 0 0 0 0
TITANIUM 0 0 0 2
POTASSIUM 0 9 0 1
BORON 76 76 109 284
SILICON 27 46 12 5
SODIUM 3 2 3 15
CALCIUM 19 19 24 64
MAGNESIUM 4 5 0 3
ZINC 15 10 14 37
BARIUM 0 0 0 1
CADMIUM 0
VANADIUM 0
ANTIMONY 0
LITHIUM 2
Water % 0.0 0.0
TAN 2.7 2.9 2.10
Oxidation 45
Nitration 4
