2005 G35 | Nissan Matic S 41k | Jatco RE5RO5A
WPB, FL
How the fluid looked
I am pretty happy, I thought I was going to look at a bad UOA heh, I did Tail of the Dragons in NC which defiantly heated my Transmission up.
I think this is a good example that color of the fluid means jack.
I will be installing an Aux. Cooler and inline filter shortly.
Originally Posted By: Oregoonian
It seems from the numbers on your report.....that the oil only has 30,000 on the ATF.
Did you make a mistake...or did Blackstone?
Your right its confusing. The oil wasn't changed at the last report, At 40k On my car I changed the fluid. 10k after that I sent the first ATF sample.
This is the second sample after 41k on the oil and the oil was changed at this sample, 81k on the car
That was 7-1/2 years ago. The OP might not even see this post let alone have the image(s).
