Home
Intake Resonator delete
Posted By: Marco620
Intake Resonator delete - 06/07/18 11:45 PM
Posted By: Marco620
Re: Intake Resonator delete - 06/08/18 12:00 AM
Sounds ultra loud now. Seems to run a hint cooler on freeway too. Butt dyno says 1 hp max... But boy is she louder now.
Posted By: eljefino
Re: Intake Resonator delete - 06/08/18 12:07 AM
I've overwhelmed by all the absence.
Posted By: gathermewool
Re: Intake Resonator delete - 06/08/18 12:40 AM
Nope.
Posted By: 2strokeNorthstar
Re: Intake Resonator delete - 06/08/18 12:47 AM
Nice. I got 2psi more boost deleting the factory stuff on a 2013 juke nismo. Intake and inter cooler pipes. Some noise is fine.
Posted By: 901Memphis
Re: Intake Resonator delete - 06/08/18 01:42 AM
I have no idea what I'm looking at
Posted By: andyd
Re: Intake Resonator delete - 06/08/18 02:02 AM
And you have company. I liked the way the stock system sounded on the 528e. My '88s had 44mm pipes exiting the cat, with a resonator ahead of the muffler.and out. Mellow and not fatiguing on highway. Guys, I'm looking at 6K$ worth of hearing aid so I can hear my grandsons speak. To many DBs for too long and the ears wear out.
Posted By: Nick1994
Re: Intake Resonator delete - 06/08/18 07:20 AM
Looks like a radiator hose to me...
I deleted the resonator on my Camry too. Not for performance, but because the replacement was expensive because the hose broke. $3 of Home Depot PVC fixed that issue crackmeup
Here's the link to that butcher job:
https://www.bobistheoilguy.com/forums/ub...ato#Post4049903
Re: Intake Resonator delete - 06/09/18 01:30 AM
That means you’re likely over-boosting. Changing parts on a (modern) turbo vehicle-without a tune is foolish. There are no ifs ands of buts about it. You may have “gained” boost, but your ECU may be pulling timing or trying to compensate for the changed intake and wrong MAF sensor reading via massive adjustments to fuel trim.
Posted By: NGRhodes
Re: Intake Resonator delete - 06/09/18 09:33 AM
Intake resonators are not just for sound reduction but allowing a reserve of air to help flow during the pumping pulses.
You won't automatically gain power from removal and probable that you will reduce power.
I do know some car do get gains from a shorted cold air intake and turbos add another dimension.
This link below is a good read.
http://planetsoarer.com/resonator/resonator.html
© 2019 Bob Is The Oil Guy
