Home
GDI Engine Wear Test Development
Posted By: JAG
GDI Engine Wear Test Development - 06/09/18 05:57 AM
https://crcao.org/reports/recentstudies2018/AVFL-28/CRC%20AVFL-28_Final%20Report_JAN2018.pdf
The trends in the wear rates sure are complicated and don’t follow simple rules. Start-stop wear is particularly significant and is worse for the 0W-16 oil than the 5W-30 oil. Be sure to check out the graphs and the photos in the appendix.
Quote:
ABSTRACT
Existing engine lubrication wear tests based on ILSAC and ACEA specifications were developed for engines and operating conditions representative of port fuel injection (PFI) engine technology. The automotive industry is trending away from the PFI engine towards gasoline direct injection (GDI) technology with approximately 40 percent of passenger cars sold in 2014 having GDI engines, many of which are turbo-charged. These turbo-charged GDI engines often produce more severe operating conditions than PFI engines due to their higher operating temperatures, cylinder pressures, and specific torques. In addition, most turbo GDI engines are downsized, therefore operating at higher loads for a greater portion of their operating cycle. Some vehicles use alternative combustion cycles or stop-start technology which further subjects the engine and lubricants to higher levels of stress compared to conventional PFI engines.
In an effort to guide the development of engine lubrication wear tests in the next ILSAC and ACEA categories, the rings, liner and rod bearings of a modern turbo charged GDI engine, a Ford 2.0L Ecoboost engine, were irradiated and the engine assembled and placed on a test stand. The irradiation of these engine components resulted in the formation of different isotopes, depending on the component material. A series of in-field operating conditions were selected and the engine operated at these conditions using both a SAE 5W-30 oil and a SAE 0W-16 oil with the same additive package. Using the SwRI® Radioactive Tracer Technology (RATT®) the level of radioactive particles in the oil, present due to wear of the irradiated engine components, can be detected and the strength of the signal for each isotope can be correlated with the mass of wear material in the oil.
Results showed no measureable wear in the connecting rod bearings, higher wear response from transient than steady state engine operating conditions, noticeably higher wear during stop-start and roughly only two thirds of the operating conditions resulted in higher wear in the measured engine components using SAE 0W-16 oil over SAE 5W-30 oil.
Quote:
CONCLUSIONS
A project was undertaken to investigate the wear of rings, liner and connecting rod bearings in a Ford 2.0L Ecoboost engine using Radioactive Tracer Technology® to track real time wear of the components individually. The results clearly show the operating cycles that created significant wear in the irradiated engine components.
A significant amount of data was produced for the five irradiated engine components across the engine operating test matrix. The main findings are:
• After initial run-in, no measurable wear was recorded for the connecting rod bearings
SwRI Final Report, Project No. 08-22469 Page 14 of 15
Comparing the wear rates using SAE 5W-30 and SAE 0W-16 oils, lower viscosity lubricant resulted in higher wear across roughly two thirds of the engine operating conditions
• In general, transient engine operating conditions created higher wear than steady state conditions
• The stop-start cycles produced some of the most significant difference in wear rates for the two lubricants and often the highest wear rates recorded
• The cold start cycles operated at the beginning of every day of testing did not exhibit appreciable wear rates on any of the irradiated components
• It is intuitive that higher load would result in higher wear between the ring face and liner. However, the results of this work show that not to be entirely accurate, with only transient speeds at high load giving significant top ting face, top ring side and liner wear. The WOT 3500 at maximum boost only produced significant wear on the top ring side when running with SAE 0W-16 oil.
Posted By: csandste
Re: GDI Engine Wear Test Development - 06/09/18 07:06 AM
Doesn't Ford spec 5w20? Would have been interesting to see that weight thrown into the mix for comparison.
Posted By: demarpaint
Re: GDI Engine Wear Test Development - 06/09/18 10:13 AM
Thanks for posting. After a quick read start/stop seems to be a real killer with the lower viscosity oil, especially with 0w-16 in the sump.
Posted By: Ducked
Re: GDI Engine Wear Test Development - 06/09/18 10:15 AM
Dunno, general superiority of higher viscosity oil and higher wear from transient than steady state conditions doesn't seem all that unexpected.
Low cold start wear doesn't fit the "90% in the first 10 mins" (or whatever) recieved opinion but I don't think I've ever seen the source for that.
The test method acronym being RATT might cause some confusion though.
Posted By: spasm3
Re: GDI Engine Wear Test Development - 06/09/18 01:47 PM
I have always wondered about hot, short trips with the lighter oils. When the engine cools, of course you have thicker oil. But the weight of the crank is sitting on the bearings with a 7-8cst oil and then rotates on start up before pressure comes up. Seems worse than cold start up to me.
Posted By: volk06
Re: GDI Engine Wear Test Development - 06/09/18 02:15 PM
Ford specs 5w-30 in some of the ecoboost engines.
Posted By: double vanos
Re: GDI Engine Wear Test Development - 06/09/18 02:45 PM
Ford may spec 5w-30 for the 3.5 EB ; mine is on a steady diet of 0w-40. New start sequence for a new EB F150: twist key to start, hit stop/start deactivation button, then put it in sport mode to get all 10 gears in the mix before driving.
Posted By: carviewsonic
Re: GDI Engine Wear Test Development - 06/09/18 03:36 PM
Thanks for posting. I'm not a fan of stop/start, but still surprised that they found some of the highest wear levels during stop/start events. I thought that warm starts produced no appreciable wear, and that cold starts were the major source of wear. This wear test shows the opposite. Interesting!
Posted By: dblshock
Re: GDI Engine Wear Test Development - 06/09/18 03:44 PM
well so much for the thin crowd again, my lubricated fuel should come around one of these days too.
Posted By: CT8
Re: GDI Engine Wear Test Development - 06/09/18 04:15 PM
Thicker oil usually has a thicker oil film / wedge.
Posted By: CT8
Re: GDI Engine Wear Test Development - 06/09/18 04:16 PM
Kerosene.
Re: GDI Engine Wear Test Development - 06/09/18 04:42 PM
I'm not a fan of it either, but it is a technology that most likely will be forced upon me at some point. Hopefully if I do end up with it it can easily be disabled. After looking over that link I wonder if they'll be changing oil specs or back specing to something "thicker" at some point for engines with stop/start. hide Once again only time will tell.
Posted By: Dyusik
Re: GDI Engine Wear Test Development - 06/09/18 04:55 PM
While I'm sure the activated additives should negate this issue, I too get queasy about it, so I spike my 0w20 with a few quarts of 10w30.
Re: GDI Engine Wear Test Development - 06/09/18 05:03 PM
I think CAFE pressure on manufacturers will keep the thinner grades in play. Our new Impala 3.6L specs 5w30 and does not have stop/start or cylinder deactivation. Old School! Well, except for DI...
Re: GDI Engine Wear Test Development - 06/09/18 06:49 PM
I think so too.
Posted By: Shannow
Re: GDI Engine Wear Test Development - 06/10/18 11:12 AM
JAG,
it's a really great paper...the '60s and '70s isotopically charged wear measurements, and a modern ability to test in real time.
In addition to your points of note
(they didn't include "flow")
Very pertinent to UOA is the daily cycle of wear materials present, due to materials dropping out in the cooling cycle...don't change the oil cold, or use a run to luke warm to drain/UOV.
Posted By: bigj_16
Re: GDI Engine Wear Test Development - 06/11/18 12:58 AM
Interesting tests. I have two issues, however. First, this engine was not designed to run on 0W-16 oil. Secondly, it would have been much better if they had used separate identical engines for each oil. Preferably, two engines per oil.
Posted By: Shannow
Re: GDI Engine Wear Test Development - 06/11/18 01:32 AM
I think using the one engine longitudinally through the tests eliminated the variable of radiotracing variabilities through dosing them up.
Bookend testing in a single engine is pretty common in this sort of testing verus destructive testing like Sequence IVA for example.
Posted By: oil_film_movies
Re: GDI Engine Wear Test Development - 06/12/18 01:58 PM
Right. Ford says to use 5w30 or 0w30 in this engine, not 0w16, and I don't think this engine had the special crank bearings stop-start engines have(?); of course rings were the real issue though.
(Put 0w20 in a current Honda 1.5T, fuel dilute out the wazoo, and you're down to a 0w16 or 0w8 very fast.)
Re: GDI Engine Wear Test Development - 06/12/18 02:40 PM
OK, extra wear with 0w16 in a 5w30 engine, an expected outcome.
Now I wonder if loading the thin oil up with tons of moly (like Idemitsu Zepro 0w20 or Mazda 0w20) and/or throwing in something extra (like Castrol Magnatec) using polymer esters would make a difference. A lot of boundary additives.
Posted By: bigj_16
Re: GDI Engine Wear Test Development - 06/13/18 06:12 PM
That ring issue was probably either a defect or related to the detonation occurrence.
I am not knocking smile the test, per se, I just think it could have been a little more scientific.
Posted By: bigj_16
Re: GDI Engine Wear Test Development - 06/13/18 06:18 PM
I think the 0W-40 is a good idea for where you live. I am running the QSUD 5W-30 D1G2 in our 2.7's this summer, as it is one of the thicker D1G2's. Probably doing the same next year. Ran the PP D1G2 in one over the winter, and M1 AFE 0W-30 in the other. I have a little stockpile of both and will run it over the next two winters. We are thinking of moving to a warmer climate in a couple of years. If we do, they will get the 0W-40.
Posted By: JAG
Re: GDI Engine Wear Test Development - 06/14/18 12:00 AM
I think there are some misunderstandings of the intents of the effort and testing. The intents were:
1. To guide the development of engine lubrication wear tests in the next ILSAC and ACEA categories, which will replace the very old technology engines used in many existing engine oil test standards, use a modern, turbocharged GDI engine.
2. Develop a test matrix to operate the engine through a series of in-field operating conditions expected to create wear of the engine components.
3. Discover which engine conditions created wear in which engine components
4. Use the recommended lubricant grade for the engine – SAE 5W-30, and a low viscosity lubricant - SAE 0W-16, to investigate effects of reduced viscosity.
Hopefully it is known that in engine tests, such as Sequence IIIG, that either many or even all viscosity grades have to be used in the same type of engine. When 5W-20 is tested, it does not get tested in a version of the engine designed for 5W-20. That’s strange and far from ideal, but there are some valid reasons for doing it that way.
Re: GDI Engine Wear Test Development - 06/14/18 09:09 AM
Good points.
Posted By: Virtus_Probi
Re: GDI Engine Wear Test Development - 06/16/18 11:52 PM
The QSUD is on the thicker end for a 5W30 at 100C, 11.6 cSt, and I also notice the CCS viscosity at -30C is quite good at 3800 cP. The MRV viscosity at -35C is well over double the CCS at 12550, which I believe Shannow informed us quite likely indicates that a good dose of pour point depressants was used (meaning the base oils are not inherently low viscosity at very low temps).
Wish we had HTHS and NOACK loss test results for this oil, but the May PDS that can be downloaded from the linked page looks pretty good for what it shows. QSUD used to have very low NOACK loss considering it was a "bargain" oil (i.e. cheaper than PP and M1).
https://www.quakerstate.com/en_us/products/motor-oil/quaker-state-ultimate-durability.html
Posted By: PimTac
Re: GDI Engine Wear Test Development - 06/17/18 04:22 PM
The start-stop feature is one I hope to not own. As someone above mentioned though, it might be inevitable. Some years ago I rented a Nissan Altima hybrid. During that time the morning temps were in the high teens and low twenties. Starting up, the car went on battery for the first few blocks then the engine came on. With no warm up or chance to get the oil up to pressure I wondered what the long term wear would be on that engine.
© 2020 Bob Is The Oil Guy
