Specifications
Burleson,Texas
I have a 2017 Ford Edge Titanium with the 2.0L EcoBoost engine.
What are the normal parameters for:
Oil pressure
What is the set pressure for the oil pump relief valve?
Normal running coolant temperature
At what temperature does the cabin heater start to provide heat?
^ Yeah really.
Item Specification
Oil pressure (hot @ 2,000 rpm) 29–60 psi (200–414 kPa)
Cooling System Pressure
Complete cooling system maximum pressure 145 kPa (21 psi)
Pressure relief cap 145 kPa (21 psi)
Radiator pressure test (removed from the vehicle) 138 kPa (20 psi)
Thermostat Opening Temperatures
Starts to open 80°C-84°C (176°F-183.2°F)
Fully open 97°C (206.6°F)
Oil pump relief and temp for cabin heat I didn't see in the FSM.
