Browsing old threads regarding coolant on BITOG i noticed that time and time again, OAT coolants are accused of poor protection of Lead solder, brass and copper.
What gives?
https://www.sae.org/publications/technical-papers/content/2000-01-1979/
This SAE study while old, does not make it less relevant, it says that Carboxylate OAT coolants provide SUPERIOR protection to Solder than conventional IAT Silicate coolants.
Yet there are many albeit anecdotal accouns of people seeing badly degraded lead solder due to using OAT coolants.
OAT coolants are also accused of poor protection for Copper and Brass, the primary corrosion inhibitors that protect copper and brass are Azoles in their various forms such as Mercaptobenzotriazoles.
I don't know of any coolant formulation that does not contain them, so in theory any coolant that contains some form of Azole , wether organic or inorganic, or a HOAT should keep the copper and brass heater cores or even radiators happy...
I have also read that Silicate helps to some degree to protect solder and copper / brass.
Right now i am running VW G12++ im both my Fords, it's an OAT Carboxylate coolant with Sebacic as the main OAT inhibitor, and between 400-500ppm of Silicate. ( Apparently no 2-Eha )
It claims to protect Cast Iron, Alu, Copper, Brass and Solder for up to 5 years before needing changing, and claims total neutrality regarding rubber seals and hoses.
Coolant experts, chime in with your knowledge, can an OAT Carboxylate coolant protect Solder, copper and brass well or no?
What gives?
