Home
Peak Global Life Time-Is it really "Life Time"
Posted By: willbur
Peak Global Life Time-Is it really "Life Time" - 06/05/18 04:51 PM
Greetings-
What makes Peak Global Life Time coolant "Life Time". Is it really "Life Time", or is that just marketing? All other coolants specify a change frequency/mileage, but not this brew. I would think if its truly "Life Time", car manufactures' would be all over it.
Posted By: maverickfhs
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 05:49 PM
At least, I am sure there's nothing as 'lifetime'
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 05:50 PM
But subscribing to it
Posted By: SirTanon
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 06:07 PM
I suspect that the use of the phrase "Life Time" in this based on the following:
The coolant is a "super long-life" coolant, which an be used for a ridiculously long time. Add to that the term "Global" in the name, and you also add that it can be used in any vehicle. Your average consumer interprets that to mean that they can use it in any car they own without concern, an that they can leave it in pretty much 'forever', which since most (90+ percent) consumer car owners only keep their cars for 5 years or less means that for them, it essentially IS forever.
Posted By: SHOZ
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 06:13 PM
I use the Farm and Fleet long life universal. Made by Peak. Buy a case at a time and just about anytime the coolant gets drained for some reason new coolant goes in,long life or not.
Posted By: John_K
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 06:32 PM
My mechanic says lifetime means "until it fails because it needed new fluid." Applies here.
Posted By: SHOZ
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 06:39 PM
On my third set of 'Lifetime Windows' in my house over 35 years
Posted By: skyactiv
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 06:59 PM
That is the coolant I had in a 07' WRX I once owned. I bought the concentrated type and mixed it 50/50. Subaru was still using traditional coolant and called for the change interval at 30K miles or 30 months. I sold the car with 136K, only changing the coolant once and never had an issue.
Posted By: maxdustington
Until the system needs to be serviced (water pump, heater core, hoses, thermostat), 100k KM max before one of those events.
You have to assume low mileage cars are more likely to get the real thing, "global" coolant is for emergencies where the system is probably going to get flushed. Or some high mileage beater that just gets generic coolant now.
Posted By: skyactiv
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 08:15 PM
Correction: Looking at my maintenance log on the PC, I did change the coolant again at 105K miles when I changed the timing belt.
Posted By: 3800Series
Re: Peak Global Life Time-Is it really "Life Time" - 06/05/18 11:22 PM
Life time means nothing unless it's specified. You could always call and ask them "whose life time" the life of the car? The life of my pet dog? My life?
You get the point.
Posted By: pbm
Re: Peak Global Life Time-Is it really "Life Time" - 06/06/18 12:28 AM
My 2008 Corolla came with Toyota pink which is rated for 10 years/120K on the FF....I changed it out after 7 years and 75K to PGL....I just changed it again at 112K (and 4 years) using PGL (again).....I used distilled water both times so I'll probably go 6 or 7 years or until the car is sold.
So to answer your question....I don't think any coolant is 'LIFETIME" but some, like Toyota pink and PGL can go for 7 to 10 years and over 100K.
PS: I think that changing LL coolant every year or two is a waste and unnecessary...especially with cars with timing belts where the water pump gets changed every 80 or 90K. Every 4 or 5 years is fine with a LL (EL) coolant...IMO..
Posted By: Sayjac
Re: Peak Global Life Time-Is it really "Life Time" - 06/06/18 11:45 PM
Here's what Peak Old World says the term "Lifetime" means for PGL. First bullet point.
"Provides guaranteed 'lifetime' protection for as long as you own your vehicle when a complete cooling system flush and fill is performed and specified maintenance followed." Seems a reasonable explanation and definition imo.
https://peakauto.com/wp-content/uploads/2017/01/PEAK_Global_FS_spec_sheet_2015_noback_LORES.pdf
It's good for 'at least' as long as the long(est) service interval PHOATs and OATs like Dex, which is a long time. And no 2eha. There isn't a PC application that with a complete flush I wouldn't trust PGL as the AF. Using it now in an older Tacoma originally specing red LL. Almost 5 years interval now and original radiator.
PGL a good AF imo.
Posted By: willbur
Re: Peak Global Life Time-Is it really "Life Time" - 06/07/18 12:45 PM
Sayjac-
They're slick with the wording- its "Life Time" if one does the required coolant changes/maintenance specified in the Owner's Manual, most likely 5 years. Big deal- any quality coolant can do this.
Its not a fill and forget coolant like its name suggests/implies (in my opinion).
Posted By: Sayjac
Re: Peak Global Life Time-Is it really "Life Time" - 06/07/18 01:33 PM
I'd say it would be "slick" if they didn't give or hid their definition of what Lifetime meant for warranty purposes, imo. That said, I don't get caught up in the semantics of the name. More important, it's a good AF that in my observation is generally well respected in bitog and has been since I joined.
And not just any quality coolant is an extended life OAT AF with no 2eha (found in Dex and Dexclones/Prestone) making it suitable for use many applications.
I'd think anyone with some common sense AND knows how to read would realize the term Lifetime to be taken with a grain of salt.
Posted By: willbur
Re: Peak Global Life Time-Is it really "Life Time" - 06/08/18 12:10 AM
"...grain of salt"?
What else is to be taken with a grain of salt in any of their statements/claims? My question was not about your wonderful experience in using it, but are they sincere/truthful in their claim of "Lifetime"?
© 2019 Bob Is The Oil Guy
