Home
Aircraft related, what would you do with $52K?
Posted By: Exhaustgases
Aircraft related, what would you do with $52K? - 12/07/19 11:43 AM
At 2:52 the price of 2 fan blades.
https://www.youtube.com/watch?v=HDxcBWZUCTI
Posted By: rooflessVW
Re: Aircraft related, what would you do with $52K? - 12/07/19 01:25 PM
Coffee
I'm staring at at one of our EC135 T2 aircraft right now, that iis in for a 1000hr inspection. So far we have on order to replace:
-One main rotor blade - $62,000 repaired, $128,000 new
-Several main rotor flight control mixer components - $15,000
-Two engines firewalls - $17,000 and $6,000
And a bunch of other tiny, random, expensive pieces. Aviation is n't cheap. The bigger the bird, the bigger the prices.
Posted By: AZjeff
Re: Aircraft related, what would you do with $52K? - 12/07/19 01:51 PM
What defect causes a main rotor blade to need replaced but still flying to a 1000hr inspection? ???
Posted By: tom slick
Re: Aircraft related, what would you do with $52K? - 12/07/19 01:53 PM
I remember replacing enough expensive parts in a day that I could have bought a new Ferrari each time.
Re: Aircraft related, what would you do with $52K? - 12/07/19 02:03 PM
No continuity between the static discharger at the tip of the blade and the grounding strap at the root.
Posted By: AZjeff
Re: Aircraft related, what would you do with $52K? - 12/07/19 02:30 PM
Got that.
My work is a mil subcontractor and we make fuel cell enclosures for a number of military helos. Every connection point has to have conductivity with every other point with minimum values. Our current project tank has close to 50 connection points. The conductive silver epoxy is something like $50/10 gram pack and each tank gets 17 packs. We also make the internal seat cushions for the birds. Knowing what these simple parts sell for it's no wonder flying things cost what they do.
Posted By: frankbee3
Re: Aircraft related, what would you do with $52K? - 12/07/19 03:11 PM
I sold my Cessna 180 because I was certain that a couple of cylinders had to be removed and I was staring at an ADS-B out mandate.
I couldn’t even fathom owning a helicopter, even a Robinson..
I think I would find it stressful having to order the parts for the EC 135. “Can’t we just fly another 200 hours on those rotor blades?...”
Posted By: WagonWheel
Re: Aircraft related, what would you do with $52K? - 12/07/19 03:12 PM
Coffee
Guess that's why they charge $20k for an air ambulance ride!
Posted By: BusyLittleShop
Re: Aircraft related, what would you do with $52K? - 12/07/19 09:35 PM
I'd go for a used Yak 52TW (tail wheel) aerobatic trainer because its like flying a WarBird...
[Linked Image]
[Linked Image]
Posted By: Rand
Re: Aircraft related, what would you do with $52K? - 12/07/19 10:54 PM
52000? that covers a new toilet seat right?
© 2020 Bob Is The Oil Guy
