2006 LBZ Duramax, 5,300mi, Delvac1 CK-4
Richmond, VA
Previous UOA for reference:
HERE
I left the truck tuned as it was before and cleaned the air filter.
Started off with a NAPA Platinum Filter then, after receiving the previous UOA, I installed a Fram HM9100 ($1.50 @ WM) at 981mi into this oil change.
I did not top it off when I changed the filter.
At 5314mi I sampled the oil via the oil filter housing; I removed the filter and let the oil from the center of the housing drip in the sample bottle.
Now the truck has a Fram Ultra installed and I added 1/2 quart to get back to full.
Code:
MI/HR on Oil 5,314 15,592 10,746 21,466 13,893
MI/HR on Unit 148,361 143,047 127,455 106,671 85,205
Sample Date 08/05/17 05/03/17 08/10/14 01/13/14 03/05/12
Oil Delvac1 ESP CK-4 M1 TDT Rotella T5 Rotella T6 5w-40 Rotella T6 5w-40
5W-40 5W-40 10w-30
Make Up Oil Added 0 qts 0 qts 0 qts .5 qts (Filter) 0 qts
ALUMINUM 3 4 4 6 6
CHROMIUM
IRON 23 47 49 24 34
COPPER 1 4 3 4 14
LEAD
TIN 3 3 2 2 3
MOLYBDENUM 36 2 3 67 62
NICKEL
MANGANESE Not Tested Not Tested Not Tested Not Tested 1
SILVER
TITANIUM
POTASSIUM 2
BORON 76 43 15 23 38
SILICON 7 13 11 6 8
SODIUM 1 8 5 10 4
CALCIUM 1212 1354 2517 860 970
MAGNESIUM 828 990 50 1171 1258
PHOSPHORUS 981 1185 1091 1070 1098
ZINC 1207 1385 1254 1312 1309
BARIUM
SUS Viscosity @ 210°F Not Tested Not Tested Not Tested Not Tested 77.3
cSt Viscosity @ 100°C 13.3 17.0 12.7 15.0 14.84
Flashpoint in °F Not Tested Not Tested Not Tested Not Tested 420
Fuel %
Antifreeze % No No No No 0.0
Water %
Insolubles % 0.6 1.6 0.5 0.3 0.1
TBN 8.8 7.0 6.1 7.2 8.3
Originally Posted By: stockrex
"Cleaned the air filter"
K&N ?
I would guess so too.
Silicon value is pretty good in this sample .... so whatever the airfilter is its not doing a bad job.
But if I calculate the numbers of this sample to the milage of Mobil 1 TDT, TDT has done a better job ... and still had a 17 cSt after 15000 miles?
K&N ?
It's a 10 year old AFE ProGuard 7-Layer.
The TDT from the previous fill was CJ-4
Delvac 1 ESP 5W-40 has moly in it now? This is new for the CK-4 formula? On the older UOAs of Delvac 1, there wasn't any moly to speak of, right?
