Home
Plugged Grease Nipple Solution
Posted By: Gebo
Plugged Grease Nipple Solution - 03/17/20 08:18 PM
I may be the only person that didn't already know this but I had a grease nipple that would not accept grease. It was one of those that was pressed in and you couldn't screw out. I fiddled and I faddled until I noticed my propane torch standing at attention on my workbench. Hmmm.....
I fired that baby up and heated that nipple for about 5 seconds and she took grease like my dogs eating raw hamburger. GONE down the PIPE.
Maybe this will help someone???
I'm starting to learn fire and heat can do amazingly good things.
Posted By: Dinoburner
Re: Plugged Grease Nipple Solution - 03/17/20 08:48 PM
Either that or take the load off the device thats up against the fitting.
Posted By: George7941
Re: Plugged Grease Nipple Solution - 03/17/20 10:13 PM
What you do not realize is that heating the fitting with a propane torch will ruin the spring that holds the check ball. The fitting now no longer seals and grease can leak back out, contaminants can go in.
Carefully heating the fitting with a heat gun till the grease starts flowing, without overheating might save the spring.
I have encountered my share of pressed in fittings and dislike them. I have had to tap new threads and replace them with threaded grease nipples many times.
Posted By: tc1446
Re: Plugged Grease Nipple Solution - 03/17/20 10:37 PM
I have a heat gun and never thought of using it. Went to tractor dealer this morning and paid $9 for 4 new ones!
Good info.
Posted By: atikovi
Re: Plugged Grease Nipple Solution - 03/18/20 12:43 AM
They make special tools for that, https://www.nationaltoolwarehouse.c...P1JbTiOL-scQbTHRgQdG4kgXF70aAqMlEALw_wcB
Posted By: kstanf150
Re: Plugged Grease Nipple Solution - 03/18/20 12:57 AM
Yeah
Or keep a few spares in your tool box and just change em out
Their really cheap
Posted By: Kestas
Re: Plugged Grease Nipple Solution - 03/18/20 12:59 AM
He said he couldn't remove the grease nipple.
I too keep a stash of grease nipples that I use once every 20 years. I started stashing when I bought a new 74 Torino that came with screw plugs where grease nipples should be at the ball joints.
Posted By: Gebo
Re: Plugged Grease Nipple Solution - 03/18/20 01:51 AM
This nipple was pressed in and I couldn't screw it out.
Posted By: oldhp
Re: Plugged Grease Nipple Solution - 03/18/20 05:37 AM
5 seconds of heat? You didn't hurt anything.
Posted By: Gebo
Re: Plugged Grease Nipple Solution - 03/18/20 10:22 AM
I know grin2
Posted By: WyrTwister
Re: Plugged Grease Nipple Solution - 03/18/20 01:00 PM
That is what I was thinking . You certainly did not damage a spring . If you would have damaged anything , it would be a rubber seal / boot . Which I doubt .
Posted By: Gebo
Re: Plugged Grease Nipple Solution - 03/18/20 01:22 PM
It is on the blade spindle of a Zero Turn.
Posted By: Rick505
Re: Plugged Grease Nipple Solution - 03/18/20 04:19 PM
Originally Posted by atikovi
Or the cheaper "pocket" model for occasional use
https://www.nationaltoolwarehouse.com/Pocket-Grease-FittingJoint-Rejuvenator-P47527C875.aspx
Posted By: atikovi
Re: Plugged Grease Nipple Solution - 03/18/20 07:49 PM
Originally Posted by Rick505
I venture that many here are tool junkies and any excuse to buy one is good enough, especially the complete set. Better to have a tool you don't need than not have a tool you do need.
Posted By: super20dan
Re: Plugged Grease Nipple Solution - 03/18/20 11:02 PM
i use an awl and poke the ball in the nipple and move it around and then the fitting will usually take grease. not 100% but worth a try
Posted By: TheLawnRanger
Re: Plugged Grease Nipple Solution - 03/18/20 11:14 PM
Some folks use those hooks/pick you get for 99 cents at HF to unplug an alemite.
Posted By: MCompact
Re: Plugged Grease Nipple Solution - 03/19/20 03:42 PM
My 1993 Pathfinder’s front suspension was fitted with plugs as well.
Posted By: MCompact
Re: Plugged Grease Nipple Solution - 03/19/20 03:43 PM
edit
© 2020 Bob Is The Oil Guy
