Home
Torque converter drain bolt - No sealing washer?
Posted By: Fitz98
Torque converter drain bolt - No sealing washer? - 05/23/19 06:40 PM
98 Expedition 5.4 4x4 4r100 tranny.
I just removed my torque converter drain bolt and was a little surprised to see no washer or thread sealant.
Is this the way it is supposed to be, just the bolt only?
Also anyone have torque for torque converter drain bolt, transmission pan bolts and transmission pan drain bolt?
Posted By: sdowney717
Re: Torque converter drain bolt - No sealing washer? - 05/23/19 09:18 PM
Had 2 drains on a 1962 Buick transmission torque converter. They were 1/8" NPT plugs, so no sealer was used.
Posted By: The Critic
Re: Torque converter drain bolt - No sealing washer? - 05/23/19 09:36 PM
On the MB 722.9 transmissions the torque converter drain plug uses a copper washer and thread locker.
Bdcardinal is the person who can help you with this.
Posted By: bdcardinal
Re: Torque converter drain bolt - No sealing washer? - 05/23/19 10:08 PM
No washer listed. The p/n is 87650-S with a description of "plug - dry seal tapered thread - 1/8-27"
Posted By: CT8
Re: Torque converter drain bolt - No sealing washer? - 05/23/19 10:30 PM
Pipe plug?
Posted By: ragtoplvr
Re: Torque converter drain bolt - No sealing washer? - 05/23/19 11:09 PM
Pipe plug is not the same as Dry seal. Look it up.
Posted By: The_Eric
Re: Torque converter drain bolt - No sealing washer? - 05/24/19 12:48 AM
It's just 1/8 pipe. Just screw it back in with no sealant - you don't want any foreign sealant goo inside the converter/trans
© 2019 Bob Is The Oil Guy
