Home
Wife's RAV4, burnt clutch, DIY
Posted By: Superflan
Wife's RAV4, burnt clutch, DIY - 02/08/19 08:48 AM
Hi,
I maybe underestimated a disaster that was waiting to happen.
When we bought the used car, I noticed the clutch was slipping sometimes, but mainly after engaging each gear.
Later I figured out that hydraulics were the problem, and cleaning slave cylinder (all greasy inside) and flushing fluid solved 80% of clutch behaving issues.
But on occasions, like giving full throttle at sub-midrange RPMs, it slipped anyway until catching up at a higher speed. I then figured that even if clutch pack was replaced somewhere long before the purchase, that hydraulics was likely the root problem and that it continued to wear the actual clutch pack
Fast forward today, it slips at every hill, and I think it won't last more than a work day. I will check hydraulics in a minute to insure it's not sticking.
Any clue of special things when replacing a clutch pack and dual mass flywheel on this MY2001 TOYOTA 1AZ-FE RAV4 ?
Posted By: Gasbuggy
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 10:37 AM
I can't tell you any specific things you will need. But I can say that when I was 20 I replaced a clutch into a FWD toyota with a friend of mine who just like myself, had no clue what he was doing. We got it done and it worked.
Posted By: Audios
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 01:24 PM
Youre going to need alot alot alot of time and even more patience. Book time is 18.9 hours for 4wd!!!! This could be a killer for the car depending on how much you want to sink into the car, but we could be in the 3000 range at a shop. Insane!
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 01:39 PM
18h! Are you sure it's for the same car? Seems overkill
Posted By: Cujet
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:00 PM
18 hours for a shop means more than that for someone working on jack stands. Yikes.
Cars are such a pain sometimes. As an older guy, I simply don't have the time or energy to be dealing with transmission removals in my driveway. I truly feel for you.
I'd rather be out on my KTM, misbehaving.......
Posted By: Miller88
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:02 PM
On vehicles with transverse engines, you have to do a significant amount of extra work.
Front suspension has to come apart to be able to get the axle shafts out. Linkages have to be disconnected (and they are never in good locations). If you're lucky, the transmission can come out the top - otherwise you're dropping a subframe/kmenber/engine cradle/whatever-it-is to get the transmission out. Intake tubes, battery box ... all sorts of junk in the way with transverse engines.
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:06 PM
I'll document it so we can see what we have to see smile it's gonna be interesting
Posted By: supton
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:09 PM
Being AWD I could see it being a long job.
IIRC it was about an hour to drop the trans in my Jetta. But my mechanic had done it a bunch of times, knew what he was doing. But no extra driveshaft etc in the way.
Cars suck. Sometimes I think about buying new and flipping every 150-200k (6-10 years, give or take). Not the cheapest solution but perhaps least work involved.
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:21 PM
Duplicate post
Posted By: Miller88
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 02:23 PM
I said I was done with new or even newer vehicles. I figured with a small fleet of older vehicles, I could make it work.
Until all three broke at once
Posted By: BigD1
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 03:00 PM
Yes they are a royal PITA.
If the trans comes out the bottom, they will probably need an engine support bar.
https://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Posted By: AZjeff
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 03:04 PM
Originally Posted by Superflan
Hi,
We've probably all done that with used cars with varying degrees of work and expense involved to correct the oversight. In another thread someone mentioned a free car that he had $2300 in and wasn't done yet. Ouch.
Grateful I don't have to deal with vehicles in their end of life miles. Hope it all doesn't have to come out the bottom. Good luck.
Posted By: supton
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 03:09 PM
LOL Sorry, I can see that happening. MTBF all deciding to hit at once.
Posted By: KrisZ
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 03:29 PM
That clutch is toast. A slipping clutch is almost never the fault of hydraulics, unless there is a leak on the clutch, as they are used to disengage the clutch, then the clutch springs engage it and ensure it stays engaged.
I would look for a single mass flywheel conversion kit. It will be less expensive than a dual mass flywheel and should last for the life of this vehicle no problems.
Posted By: Audios
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 04:45 PM
2WD drops it down to 6.7 hours, so heres hoping that its only a front wheel drive?
Posted By: DoubleWasp
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 04:48 PM
Agree. Nothing good comes of dual mass flywheels. If it's the type with the springs, I bet some are broken.
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 06:07 PM
I have receipt of clutch repair at 80000km or so, it's 144000km and toast. 60000km is rather short for a set. The hydraulics were sticking when pressed, I opened and cleaned 2 times because OEM 17 years DOT3 fill was forming gunk in master and slave cylinder. I guess this wore out the clutch prematurely. I could see the fork still moving when pressing pedal and going out of car before cleaning inside
Seems I'm wrong and it's not a DMF (I'll see it live tomorrow)
It's a 4WD
Posted By: bullwinkle
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 06:50 PM
That was recently my situation-GMC developed a pretty big fuel leak (hose under the intake, of course), and the xB’s exhaust decided to fall off. Good thing it was 65F & mostly sunny last Saturday! Had to get them fixed before the XJ or F-450 got any ideas...
Posted By: KrisZ
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 06:59 PM
Wow! You learn something new everyday. I never encountered or heard of something like this before. The fluid must've been really gunky to hold off the clutch plate pressure.
Thanks for sharing this.👍
Posted By: mk378
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 07:13 PM
Sounds like contaminated fluid, in that case the only cure is to replace both cylinders and flush the line well.
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 07:48 PM
Yeah me neither. The gunk looked like blue « marine » grease
I’ll monitor things carefully but now it’s working good
Posted By: benjy
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 07:53 PM
todays clutches being hydraulic generally feed of brake fluid reservoir, at least my 11 nissan frontier does. changing + flushing all fluid is generally every 5 years. can't say anything but good luck + as noted single mass fly + aftermarket can be a lot cheaper, look for you tubes + buy a service manual for specific torques. i would join + look at a Rav IV specific forum as well, good luck!!
Posted By: JC1
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 08:52 PM
The OP is in Reunion Island, I doubt there's a HF location close by.
I would try the job myself. Probably need two weekends to get it all done...
Here is a link which may help you. Not sure if any special tools are needed to access everything.
https://pmmonline.co.uk/technical/how-fit-clutch-toyota-rav4/
Posted By: Lolvoguy
Re: Wife's RAV4, burnt clutch, DIY - 02/08/19 08:56 PM
Hope it's just a hydraulic issue.
I had something similar with my BMW several years ago. The slave was fed off the master cyl (shared res.) and once the brake fluid went low enough, it caused issues with the slave.
Another vote for FWD/RWD
Posted By: Silk
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 12:03 AM
I doubt the hydraulics would wear out the clutch, the release bearing and fingers maybe, but not the clutch plate.
I haven't done the later models, but the first RAV4's were a really pain. you can't pull the gearbox back because it hits the transfer box, you can't remove the transfer because it hits the block. In the shop it's easier to drop the powertrain on the floor and jiggle it all apart. A young guy at work did one in the car last year, it looked nasty because he had the engine hanging at an angle to get the box down. Not something I'd do at home that's for sure.
Posted By: Cujet
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 03:01 AM
I’d make extremely sure the pressure plate has free play at the fingers. As a clutch disk wears the free play decreases. Replacement parts may have different dimensions and take up any slack faster.
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 05:25 AM
New parts
Posted By: Audios
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 03:52 PM
Wheres Extra EU?
Posted By: mk378
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 04:24 PM
I read that to mean "somewhere not in the EU." The telephone number would lead to Verona, Italy though.
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 06:47 PM
So, the [censored] clutch kit is out. Rivets were licking pressure plate.
Jack up the car, remove wheels, detach control arms, detach wheel pivots, remove x member, remove front driveshafts, remove half airbox, detach clutch slave cylinder, lines, remove starter motor, jack up engine, remove gearbox, done.
It took 3 hours for me and a brother's friend who did it on his RAV4 weeks ago.
Now I need to shave the flywheel that is in bad shape before putting it all back together
Next on Monday with pics
Posted By: eljefino
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 06:56 PM
well done!
Posted By: mk378
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 07:03 PM
I guess you get used to working like this, being in the Southern Hemisphere.
Posted By: KrisZ
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 07:25 PM
Nice job!
Hiwever, before spending money on resurfacing the flyweel, I would make sure you have enough thickness to play with. It just may be too far gone if the rivets were digging in.
Posted By: George7941
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 07:29 PM
The fingers look very long. All the diaphragm spring clutches I have seen have shorter fingers and part of the diaphragm can been seen, unlike this one where the pressure plate cover hides the diaphragm.
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 08:15 PM
It was a joke waiting to happen
However, before spending money on resurfacing the flyweel, I would make sure you have enough thickness to play with. It jus may be too far if the rivets were digging in.
The rivets (those in the friction disc) didnt touch on the flywheel side, only on the pressure plate side, resulting in asymmetrical wear between both sides of the friction disc. I’ll take pics of worn parts tomorrow with a full phone battery smile
Posted By: supton
Re: Wife's RAV4, burnt clutch, DIY - 02/09/19 11:16 PM
Dumb question: any easier to lift the engine instead? I see you've got it out and done with already, but if I was facing this job, I'd be wondering about that option.
Edit: good job! Sounds like it was quite the task.
Posted By: antonmnster
Re: Wife's RAV4, burnt clutch, DIY - 02/10/19 06:22 PM
Nice work!
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 02:05 AM
Attached you'll find the best I can do for now with the flywheel.
Didn't machine the ring where the dowels come because after balancing there was still a 0.05mm warp. I left that part zlone
Description: 0.10 shaved
Description: 0.30 final
Description: Final close-up
Description: Cracks final
Posted By: KrisZ
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 02:11 AM
The flywheel was definitely heat stressed. Cracks are a dead giveaway, but the different shade spots show the localized overheating quite well. It will probably hold up, but I would take it easy.
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 03:51 AM
Yeah I will not drag race it.
Today I have to put CV shafts back, suspension, replace a tie rod and it should be rolling
Posted By: clinebarger
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 04:08 AM
I've always had Flywheels "Ground", A Lathe-bit will ride over the hard spots......Just my opinion!
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 04:28 AM
If life allows us to spend some big money in cars, this toy is gonna get some uprated parts (because anyway suspension would be dead, every rubber parts, etc.)
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 04:32 AM
I thought that, but then going over with the needle tip dial gauge (how do you people call that device?) shown virtually nothing bumpy. But that was one really BIG lathe, could have put myself in it
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 05:02 AM
Dial Indicator, I guess if the lathe was big enough & you plunge the tool holder/bit head-on into the material, Maybe? Surfacing usually requires a consistency in the material being cut.
I machine a lot of automatic transmission pistons, pressure plates & drums, But am in no way a "all knowing" expert on running a lathe!
Re: Wife's RAV4, burnt clutch, DIY - 02/12/19 12:43 PM
Yeah it was a very big lathe.
Well, the car is running!
It was a great experience to learn car mechanics.
Thanks to the crowd here at BITOG, friends, brother, and brother's friends for making all this possible, all in a short delay with more than good results ! And parents for keeping my 3yr old son entertained while I do those repairs
Keep wrenching, learn something.
Bonus: old parts pics
Description: Old Friction disc
Description: Other side
Description: Old pressure plate
© 2019 Bob Is The Oil Guy
