Originally Posted By: 555
Is the min and max in the same spot on each side? One side may be for reading when engine is hot and other side when engine is cold. Just a guess
No, there's marks on one side. And the OM says to insert with the picture on the handle right side up and check the side with marks. So, waited for this AM because yesterday after she drove it it was annoying. Pull it out...oil below the low mark on that side, about 3 quarts overfilled on the side with no marks. Wipe it off, insert, check again. Now overfilled on both sides. Wipe off, blow into dipstick tube, insert, check again. Now oil in middle between add and full but on back side still overfilled. Check my Toyota...both sides read the same. Old Honda before...both sides the same. Nissans I owned before...both sides the same.
I. Just. Don't. Get. It. Probably the same reason the bottoms of the 2.5 blow. [censored] engineering.
