With 78K miles on my 2002 Lincoln 4.6L dohc I'm starting to think about replacing the original plugs. Car still drives nice though with no codes or anything. One of the few things they did right on this engine was burying the plugs under protective covers and having pretty easy access. The 3v plugs of the 2000-2004 era seem to be problematic (2 piece, get stuck easy and/or break into pieces during removal such that it is recommended to get them out very early in life). The 4v plugs don't appear to have those issues.
I did some reading on this last year and a bit more yesterday. The original Ford spec of AWSF-32EE or PP has been replaced a number of times (half thread, double plat, med electrode, stock heat range). Best I can come up with from Ford are Motorcraft SP439 or SP432 PPM...and those don't appear correct with full threads. When originally installed (to save $) they supposedly only coated one tip with platinum and pointed that side towards the combustion chamber. The specs for each bank of 4 were different on day 1. Today they aren't. The Autolite APP104 and Champion RS12PYP appear as proper replacements. The NGK numbers don't seem to be consistent. I'd probably feel more comfortable with Motorcraft plugs.
So what's the best/proper plug to reinstall? I don't plan on ever doing it again. And I don't more than another 80K on the next set.
Should I do them now or wait until 100K+ miles when something actually acts up? It does seem many people get 100K-125K miles on these.
I suspect I should have some spare boots on hand if I rip them. Dielectric grease for outside, inside of boots. What about spark plug grommets? What about the age of the coil wires as it's pretty toasty warm up there in the summers? From what I read a rubber lined socket or magnetic one is helpful to get the plugs out of the deep wells. I'm leaning towards waiting to 100K. There must be some other 4.6L owners here who have gone well past 100K miles? And if you replaced them already, what did you use, how have they worked out?
