Home
Floor jack oil recommendation
Posted By: Patrick0525
Floor jack oil recommendation - 04/20/19 04:40 PM
I have a 1993 Hein-Werner (Winner series) 2 ton floor jack part code# 68041 and never had the oil changed.
How shall I change it? What is the procedure and is your favorite oil?
It doesn't leak..
Posted By: maxdustington
Re: Floor jack oil recommendation - 04/20/19 04:43 PM
Hydro oil. I can't remember the weight.
DO NOT put ATF in there.
Posted By: Reddy45
Re: Floor jack oil recommendation - 04/20/19 05:14 PM
Autozone sells hydraulic jack oil. They will have 1 kind.
Posted By: LeakySeals
Re: Floor jack oil recommendation - 04/20/19 05:23 PM
I change every 2 years on all 3 of my jacks. They are keeping me alive, the least I can do. There are 2 types.
Regular jack oil.
https://www.walmart.com/ip/Black-Jack-Hydraulic-Jack-Oil-8-fl-oz/17757422
And a "high mileage" version. LOL
https://www.walmart.com/ip/BAR-S-LEAKS-HJ12-Jack-Oil-with-Stop-Leak/16888776
I use the high mileage version, seals are the biggest issues with jacks.
Re: Floor jack oil recommendation - 04/20/19 05:35 PM
Regular jack oil.
I am sure I need the high mileage oil since I only use the floor jack 3-to-4 time per year since 1993.
Posted By: JeffKeryk
Re: Floor jack oil recommendation - 04/20/19 06:16 PM
I got some at Wally World; then a bigger bottle from Amazon.
Old floor jacks rock; I just can't pick 'em up anymore.
Re: Floor jack oil recommendation - 04/20/19 06:45 PM
Regular jack oil.
Any pics? I have one old orange 2 ton and over the past 5 years purchased 2 Harbor freight 3 ton (64260). I must admit the cheap HF jacks are good. Flawless actually. Like how fast the "rapid pump" works. So.. if things don't work out with the old jack, consider the HF jacks.
Posted By: Kestas
Re: Floor jack oil recommendation - 04/20/19 07:26 PM
I just bought a floor jack a year ago. How often should the fluid be changed?
Posted By: skyactiv
Re: Floor jack oil recommendation - 04/20/19 07:48 PM
Walmart has it the cheapest I'm guessing. Probably near the jacks on the top shelf?
Posted By: Yah-Tah-Hey
Re: Floor jack oil recommendation - 04/20/19 07:52 PM
I use Walmart jack oil. Replace it about every two years. Just about any ISO hydraulic oil should work. Probably 32 or 46. Oil for this application is nothing special. ATF will probably work too. Just don't put engine oil or brake fluid in your jack.
Posted By: Linctex
Re: Floor jack oil recommendation - 04/20/19 09:00 PM
Whoever told you that you can not use ATF lied to you.
Posted By: Linctex
Re: Floor jack oil recommendation - 04/20/19 09:01 PM
I have never changed the oil in a floor jack or bottle jack in over 40 years of owning and using them.
Posted By: Linctex
Re: Floor jack oil recommendation - 04/20/19 09:03 PM
ATF works just fine.
Light engine oil (5W-20, 0W-20, etc ) also works just fine and will not cause any problems.
Brake fluid is not oil. ... not even a little bit.
Posted By: Kestas
Re: Floor jack oil recommendation - 04/20/19 09:09 PM
I had a cheap floor jack I bought new 20 years ago that gave up. The fluid was black. I wonder if I could have gotten more life out of it had I changed the fluid.
Re: Floor jack oil recommendation - 04/20/19 11:59 PM
Regular jack oil.
The 1993 HW pic.
Posted By: Kestas
Re: Floor jack oil recommendation - 04/21/19 12:41 AM
Last year I bought a Harbor Freight jack. It had good reviews, including people that had them for 10 years. Thumbs up from me as well.
Posted By: George Bynum
Re: Floor jack oil recommendation - 04/21/19 08:04 PM
I'd not use the newer products. At least when first introduced, Dexron VI and plain old o-rings didn't play nice. I don't know if things have changed, but I wouldn't use the new versions, whether GM, Ford, or FCA.
That said, Dexron III, especially the Mobil 1 version, was an excellent hydraulic fluid for cold winter to hot summer use, as in hydraulic garage door actuators.
Re: Floor jack oil recommendation - 04/21/19 10:31 PM
I filled it with STP hyrdraulic jack oil purchased at autozone —$4.99 They did not have the Coastal version.
Posted By: MolaKule
Re: Floor jack oil recommendation - 04/22/19 01:31 PM
You can use Hydraulic Jack Oil/Air Tool Lubricant or ATF. Do NOT use brake fluid as the seals are not compatible with brake fluid.
I find that if I want to keep a floor jack for awhile the external seal around the twist valve need to be wetted once in awhile.
There should be a filler hole somewhere on it so remove the plug and orient it so it drains out.
Refill slowly and pump it up and down a few times to get air out of it.
Posted By: Ponchinizo
Re: Floor jack oil recommendation - 05/17/19 08:44 PM
I just did the oil in mine, put STP hydraulic oil from autozone in. The old fluid came out clear and new looking, but this jack is older than I am and its been at least 15 years since it saw maintenance of any kind. Greased it while I was at it.
It's an old astroline, 2 ton. From the 80s i believe.
Posted By: Deontologist
Re: Floor jack oil recommendation - 07/16/19 10:26 AM
I'd put some Redline 0W-20 in for maximum seal swell from the POE.
Posted By: bchannell
Re: Floor jack oil recommendation - 08/18/19 11:30 PM
I can't imagine why you would want to change jack oil. There's no combustion cantamination, no shear from physical manipulation etc. Top it off when low & go with it. I don't know but maybe Amsoil makes something you could feel warm & fuzzy about. There's been Jack's used to jack houses up that haven't ever had the juice changed in them, so I doubt a few thousand pound car wouldn't be much of a problem.
Re: Floor jack oil recommendation - 12/10/19 09:46 PM
Any ISO hydraulic oil in 32 to 68 viscosity range should work fine. Really overkill. ISO 100 might also work.
Posted By: BlakeB
Re: Floor jack oil recommendation - 12/12/19 03:09 AM
Home Depot has this.
[Linked Image]
[Linked Image]
© 2020 Bob Is The Oil Guy
