Home
Should I change atf on 2003 vw passat
Posted By: joegreen
Should I change atf on 2003 vw passat - 06/16/19 11:54 PM
I am babysitting my pastors car while he is away on vacation. I am surprising him by doing some maintenance on his car. He has a 2003 vw passat 1.8t fwd with the 5hp19. He bought it used and I dont think the atf has ever been changed. It has 153,000 on it right now. It shifts great and I would really like to change the atf and filter but I do not want to run into any transmission issues down the road by changing the fluid. I am a firm believer that it is always better to change the fluid then leave it even at high miles but that is easy to say when its your own vehicle. He doesnt have alot of money and i am just trying to make the car last. What would you do? Change the fluid or not?
Posted By: JC1
Re: Should I change atf on 2003 vw passat - 06/17/19 12:05 AM
Leave it alone. It's not your car.
I know you want to do something nice, do an oil change and wash the car. That's more than enough IMO.
Posted By: Kestas
Re: Should I change atf on 2003 vw passat - 06/17/19 12:25 AM
You have a good heart, but I'll have to agree with JC1. More than once I tried to do someone an unrequested favor, only to have it bite me.
Give it a good wash and vacuum.
Posted By: Lolvoguy
Re: Should I change atf on 2003 vw passat - 06/17/19 12:27 AM
+3
Posted By: Jetsfan421
Re: Should I change atf on 2003 vw passat - 06/17/19 12:46 AM
Do not open that can of worms. Never touch a transmission that isn't yours and don't have permission to alter. God forbid anything happens after changing the fluid. Oil change and a full tank of gas, no problem imho.
Posted By: maxdustington
Re: Should I change atf on 2003 vw passat - 06/17/19 12:51 AM
Change it and don't say anything about it. Real altruism, and he will be none the wiser if anything goes wrong!
Posted By: dave1251
Re: Should I change atf on 2003 vw passat - 06/17/19 12:54 AM
This is the best course of action.
Posted By: philipp10
Re: Should I change atf on 2003 vw passat - 06/17/19 01:23 AM
IMO...the answer is a big NO. Too many things could go wrong and besides, its not your car. Cut his grass, or perhaps fill his fridge before he gets home. Tasks that cannot cause problems. The car is 16 years old.....
Posted By: irad
Re: Should I change atf on 2003 vw passat - 06/17/19 01:24 AM
I flushed the atf on a 1.8t 2003 passat at 90,000. The result was improved shifting. It took 11 quarts of Maxlife syn atf with lt71141 spec on the back. I was horrified at the black color that came out for the first 7 quarts. Glad I did it.
Posted By: 2004tdigls
Re: Should I change atf on 2003 vw passat - 06/17/19 01:39 AM
according to VW it is "lifetime" which means you change the ATF and the transmission as one unit for a cost of 5-6 thousand dollars
but check out this thread frown
http://www.audipages.com/Tech_Articles/auto_transmission/autotranservicing.html
the bottom line, it should be changed but I would not do it, take the car to a VW/Audi specialist
Posted By: SLO_Town
Re: Should I change atf on 2003 vw passat - 06/17/19 01:45 AM
Although your intentions are good, don't touch it!
Scott
Posted By: vw7674
Re: Should I change atf on 2003 vw passat - 06/17/19 02:01 AM
Do not touch it.
or do whatever the Bible directs as far as neglected transaxles.
Posted By: cjolson140
Re: Should I change atf on 2003 vw passat - 06/17/19 04:17 AM
“...for to will is present with me; but how to perform that which is good I find not. For the good that I would I do not: but the evil which I would not, that I do.”
Posted By: The Critic
Re: Should I change atf on 2003 vw passat - 06/17/19 04:56 AM
Oil Change/rotate, inspection and a wash/vacuum. That is it...
Posted By: DoubleWasp
Re: Should I change atf on 2003 vw passat - 06/17/19 05:07 AM
Let sleeping dogs lie.
Posted By: edyvw
Re: Should I change atf on 2003 vw passat - 06/17/19 05:36 AM
Do not touch it.
If you want to do something good, check whether engine has big oil filter. Those engines were notorious for sludge due to a. VW/Audi messed up oil recommendation and b. oil capacity. Solution was moving engines to proper full synthetic oils (VW502.00) and large oil filter. Often, people who are not well versed in these vehicles neglect that oil filter and get small version.
So, check that, and of it is small filter, get large, preferably VW or MANN or Mahle, and put some nice juice like Castrol 0W40. Also, check if there is rattling at the back of the engine when engine is cold. That engine has timing belt and chain. Chain is in the back and it is known to cause problems. If there is rattling, there is your way to help him.
Posted By: Char Baby
Re: Should I change atf on 2003 vw passat - 06/17/19 07:41 AM
If you choose to change the ATF, always pray first.
Posted By: rooflessVW
Re: Should I change atf on 2003 vw passat - 06/17/19 10:08 AM
Make sure he's the kind of guy that will appreciate the "surprise."
I wouldn't.
Posted By: joegreen
Re: Should I change atf on 2003 vw passat - 06/17/19 10:20 AM
He takes it to a foreign car specialist so they are familiar with working on the car. Just had the timing belt replaced and the engine does have the big filter.
Posted By: AZjeff
Re: Should I change atf on 2003 vw passat - 06/17/19 12:02 PM
In other words lie by omission to your pastor. Really?
Change the oil, detail it, mention when he gets back the ATF fluid could stand to be changed and explain the change/don't change schools of thought. If he wants it done you could offer your help. Decide now what you'd do if the tranny would start to act up.
Or offer to have it done by the specialty shop.
Posted By: madRiver
Re: Should I change atf on 2003 vw passat - 06/17/19 01:22 PM
If it were maybe a 2013 you could consider it.
However at 15 years a flea sneezing the wrong way could damage the auto transmission. I would not even suggest it to friend as your advice may lead to unrelated failure and you still potentially on the hook in their mind.
Posted By: Gimpy1
Re: Should I change atf on 2003 vw passat - 06/17/19 03:38 PM
Like others have said, don't mess with it. Depending on what transmission is on the vehicle you need 2 special tools to refill the trans and a VAG specific scan tool, which reads the transmission temp which needs to be at a certain temp in order to make sure that the trans is correctly filled. I mistakenly thought it would be an easy drain and fill on the wife's car, boy was I wrong. The VAG 6262-2 fill tool is 12 or 13 bucks plus the cost of the filter and gasket. That's not even counting the ATF (you cannot use Valvoline HM). The kit from Blauparts is 136 bucks plus shipping plus the cost of a VAG specific scan tool (50-300 bucks). So yea stay away from any "surprise" ATF changes, VW are a completely different animal than any other transmission. If you want to do some thing cool for him, give the car a super detail inside and out.
Re: Should I change atf on 2003 vw passat - 06/17/19 04:04 PM
The lord works in mysterious ways!
Posted By: joegreen
Re: Should I change atf on 2003 vw passat - 06/20/19 10:39 AM
Thanks guys you have convinced me not to change it.
© 2020 Bob Is The Oil Guy
