Home
1995 Jeep Wrangler SE 4 cylinder 5 speed.
Posted By: Honda2003
1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 03:01 PM
Guys I'm buying this jeep today. Dont really know the history of oil changes. It's not even had 3k put on it in over a year. It currently has 197k miles on it. Sounds awesome and in perfect shape inside and out. What weight oil should I put in this 4 cylinder? I was going to put in synthetic oil but I've read it may start leaking oil. Well it already has a small leak nothing major at all.
Posted By: CARJ
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 03:12 PM
My Jeeps from that era always called for 10w30, so I'd grab your favorite brand and run it.
Posted By: jeepman3071
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 03:27 PM
10w30 or 5w30 conventional will be just fine in that engine. It's basically the AMC 4.0L with 2 less cylinders. Very reliable and long-lived. Nice find!!
Posted By: Chris142
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 03:38 PM
10w30 and it takes 4 qts.
Posted By: 1978elcamino
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:17 PM
4 quarts? Wow, thats not much at all.
Posted By: Triple_Se7en
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:23 PM
Yep, that's the ticket. I would choose PYB to start-off.
Posted By: Vladiator
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:33 PM
SuperTech synthetic 10w30.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:38 PM
Thanks guys. 10-30 it is. I had no idea what weight these used. Been wanting a jeep forever and finally found a good deal.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:39 PM
Call me dumb lol but what's PYB?
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 04:48 PM
Pennzoil Yellow Bottle. AKA Conventional Pennzoil oil. Now all their bottles are yellow, but until a couple years ago the only yellow bottle Pennzoil had was the conventional oil. That is where PYB originated from.
Posted By: Chris142
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 06:06 PM
It's a good deal because it's a 4 cyl. They are great for Puttering around on trails. They are Absolutely miserable on the hwy. They can't keep up with traffic and are downright dangerous in that situation. I always had 18 wheelers trying to push me faster than my 4 cyl could go.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 06:13 PM
Thanks for the info.
Posted By: Mr Nice
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 07:28 PM
It’s in excellent shape for being 25 years old.
I’d use Rotella T4.
Posted By: avi1777
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 07:42 PM
if u drive it like a regular car,city highway ex u can put just about everything it is a good engine but if plan to off road it a lot high rev it or rock crawl it go with a full well known brand syn.as mentioned here before the price difference is very small so why not go full syn.
i personally use syn always.better in everything.
dont forget to change the diff and trans fluids as well.
clean sheet on a newly owned car is the way to go.
Posted By: avi1777
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 07:46 PM
btw I love this car it's a true hero and an american icon.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 08:11 PM
I would run T5 10w30. This Jeep is high mileage and without knowing the service history a Diesel oil could clean things up a bit. A one gallon jug should run you about 14 bucks. With a 4 qt sump and a filter there should be a multitude of combinations to get a great 10w30 and filter for 20 bucks.
Posted By: Miller88
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 08:24 PM
Good ol' 10w30 in that 2.5. They're great engines. Just as good as the 4.0.
I bet you paid a pretty penny for that nice specimen of a YJ!
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/05/20 11:33 PM
Well I was by Walmart today and picked up regular Pennzoil 10-30 and a super tech filter. I was gonna get mopar but was $4 difference. Its leaking around the valve cover some. It actually looks like it has a little to much oil in it. I think the pcv valve also might be a little clogged. Gonna clean all that off and get new pcv valve and change the oil. Serpentine belt is cracked all to pieces also. It is really clean overall everywhere even under hood and underneath. The guy change the oil when he got it a year ago and they hardly ever drove it. Oil still looks new and so does the frame filter that's on it. Smells new to. I'm changing it anyway. Was almost 40 mile trip home on the hwy. It drove really good. I'm proud of it. I stole this thing for $4,500. I been looking for 2yrs for a awesome deal. I seen this on Facebook and just so happen it was a engineer at my work that had it. I guess I just lucked out.
Posted By: bullwinkle
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 12:35 AM
I would use Valvoline Maxlife 10W30 (or even 10W40, or 15W40 if you can find it if you have low hot oil pressure, as the '98 4.0 in my sig does)-Maxlife will slow down the leaks until you can fix them, it stopped an RMS leak on my Jeep completely! It's a Jeep/AMC derived 2.5/4.0, it'll run on almost anything!
Posted By: Kruse
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 01:31 AM
I've got a '96 Cherokee with close to 300K miles on it. Your engine couldn't care less what brand of oil you put in it.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 01:58 AM
I thought about max life to condition the gaskets and seals. I even really thought about just getting super tech 10-30 but got the Pennzoil 10-30 for the first change. Oil pressure stays on 3/4 over consistent warm or cold at any rpm.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 02:02 AM
Everything works to on it. 1 thing with a problem is the gas gauge. It will only go just over 3/4 when you fill it up. It wont go all the way to full.
Posted By: ammolab
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 03:28 AM
We have a 1994 4cyl 5 speed manual “wrongler” (square headlights). Living @ 7000 ft in the Rockies it spends a lot of time @3300 rpm in the lower gears, but always gets us there.
We run Max life 5 or 10W-30 @ 120,000 miles. Have recently replaced motor mounts and tranny mount as they were shot. Steering gearbox too.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/06/20 01:20 PM
Nice score! Love the YJ Wranglers. The 2.5L is slower than the 4.0L but not "dangerous" like other posters mentioned. smirk2 Valve cover gasket is a common leak on both the 4.0 and 2.5 and is a pretty cheap/easy fix. It's hard to find a clean older Wrangler these days since most were beat up off road. The gas gauge issue is likely from the sending unit in the tank.
Posted By: Nick1994
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/07/20 05:15 AM
Nice Jeep, I don't think they're all that picky. 10w30 conventional, change it somewhat often and keep on going.
I'd worry more about making sure the cooling system is up to par.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/07/20 05:09 PM
Thanks everyone for the info..
Posted By: fins
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/07/20 11:32 PM
I’d use Rotella T4.
What he said …….older Jeep = Rotella
15-40 T4
10-30 or 15-40 T5 synthetic blend
Posted By: bachman
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/08/20 11:52 AM
Congrats,, loved mine, Had the 95 as black with grey interior and the soft top but the half doors with glass slider windows. Here in CO, the 4 cyl was a bit gut-less in the ski country at upper elevations going uphill but if not in a hurry or racing anyone, it was never a problem. Just the one time the 4.0 would have been a nice difference. At normal elevations, I don't suspect you have any worries or complaints.
I did the o/c's and used Rotella synthetic. So darn inexpensive and well rated, plus I used in everything else we owned / drove at the time including my motorcycle.
One stop shopping !!
Posted By: dlundblad
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/09/20 09:30 AM
I use Castrol Edge 10w40 HM or Rotella T6/ Mobil 1 Turbo Diesel Truck.
I’m definitely a fan of 40 weights or at least thick 30’s like Rotella T5 in the 4.0.
Posted By: Olas
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/09/20 09:59 AM
Wranglers always remind me of WWII Willys vehicles - its in the fenders and the front end I think...
Best viscosity for these is determined by climate - the SAE will give you the specifics. Whichever brand helps you sleep at night, but remember that climate dictates iscosity.
Posted By: bachman
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/10/20 09:39 AM
I miss my 74 CJ-5 that was a fun distraction for me while I was in high school and my early driving years.
Giant steering wheel, straight 6 / 232, 31" tires, snow plow suspension, soft top and MI winters. Handling and driving was like riding a donkey that was on crack.
I got into more than few scrapes with it but I could never blame the Jeeper. Kids be'in Kids I guess.
It's demise and my 'close-call' was a red light runner at 11 pm on Friday night in August of 1981.
duh
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/10/20 01:18 PM
duh
LOL
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/21/20 12:45 PM
I got it done pretty easy job on this rig. I went with PYB 10-30. I might go with synthetic next we will see. Glad I got this rig its alot of fun.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/23/20 01:08 AM
[Linked Image]
So does this mean front and rear differentials get 90wt gear oil and the transfer case gets ATF4?
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/23/20 10:39 PM
[Linked Image]
I've used ATF+4 and Dex/Merc III in the 231 transfer cases of quite a few Jeeps with no issues. The axles should get any 75w90 and the rear should get limited slip additive if you have the LSD, or 75w140 if frequently towing or running larger tires.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/24/20 12:44 AM
Thank You! I have another question. How many gallons is the gas tank? I thought it was just 10 but today I put in 10.08 gallons and it still showed 1/8 tank. When I fill it up the gauge like a 1/8th showing full. So I figured it still should have had a 1/4 tank in it when I filled up.
Re: 1995 Jeep Wrangler SE 4 cylinder 5 speed. - 03/24/20 01:37 AM
Tank size is 15 gallons I believe, but the gauges are known to be inaccurate after a number of years.
© 2020 Bob Is The Oil Guy
