Home
19 Ram Rebel oil choices
Posted By: Schwifty
19 Ram Rebel oil choices - 01/18/20 01:35 AM
Hey all,
Very long time lurker here. I finally decided to join up and ask a few questions. I purchased a new Ram Rebel and did my ritual of pulling out the factory oil at 1k and I switched it with Rotella Gas Truck 5w20 and a Fram Ultra filter. I'm about to hit 5k and I was wondering about swapping over to Redline 5w30 to prevent the dreaded issue with Hemi tick and the cam wear they have been notorious for lately. So, my questions is, swap to Redline or stick with Gas truck? The cost is not an issue for me, but I do what whats best for my truck. I tend to drive it hard in the mountains, and it will see a fair amount of offroad time crawling around forest service roads in all weather conditions. Currently the truck sees about 80% straight highway with very little stop and go. But ones spring hits it will be probably offroad every weekend. I don't tow but the bed is normally loaded with quite a bit of gear, wood, and camping and hunting equipment.
Posted By: jayjr1105
Re: 19 Ram Rebel oil choices - 01/18/20 01:44 AM
Won't hurt to try. If you don't see significant improvement then go back to $20 5qt jugs of Mobile 1 or whatever name brand oil you like.
Nevermind, I didn't realize you said "prevent". I thought you were hearing it already. I'll let the more seasoned members chime in.
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 01:52 AM
Yeah, doing this as cheap insurance. I don't mind paying for a premium oil if that is what it takes. It seems a lot of the hemi crowd likes the high moly contents of the Redline oils.
Posted By: OilReport99
Re: 19 Ram Rebel oil choices - 01/18/20 02:07 AM
Originally Posted by Schwifty
Hey all,
Do you have a tick? If no, keep using the RGT 5W-20. It is the required grade for your engine, and it carries the recommended approval (MS 6395). If you do have a tick, take it to your dealership - you're likely under warranty. The way I see it, there are two types of ticks: the ones that wear the cam lobes, and the ones "succesfully killed by Redline". For the latter, just keep using RGT. No need to bend out of shape over anecdotal "evidence".
2018 Ram owner here. Tried RL 5W-30, all I got was a parasitic drag due to the high viscosity and the conviction that Chrysler engineers know their business better than I do. CAFE notwidthstanding.
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 02:15 AM
Hey all,
Interesting response. I can appreciate that! Ok, what if I wanted to switch to Redline just for the better add pack? Is having higher counts in Moly, Zinc, Calcium and Phosphorous worth it in the long run? I'm just now getting back into n/a v-8s after spending a decade daily driving high HP turbo imports, one of which thrived on very high moly oils. I guess I am asking, for this Hemi, is the juice worth the squeeze, even if I stayed with a 5w20.
Re: 19 Ram Rebel oil choices - 01/18/20 02:26 AM
Hey all,
kschachn in 3...2...1
LOL
Posted By: 77Se7en
Re: 19 Ram Rebel oil choices - 01/18/20 02:38 AM
Hey all,
Welcome to BITOG
Since money isn't an issue and you want to avoid the tick prior to it's occurrence, then switch to Red Line and stick with it.
Excellent choice and it's great to read from a Ram owner that wants to avoid the eventual, dreaded tick right now - not after the tick starts.
Posted By: SubieRubyRoo
Re: 19 Ram Rebel oil choices - 01/18/20 02:42 AM
OP, since you've been lurking, you've probably seen it here before... NO oil, regardless of its additives, can "fix" an engineering or manufacturing problem. Search the board for something like "Hemi SADI camshaft". That being said, in its HP Hemis they use PUP 0W40 from the factory, so that would be as robust a choice as any...
Posted By: Danno
Re: 19 Ram Rebel oil choices - 01/18/20 02:45 AM
For my Grand Cherokee Hemi, I'm sticking with PYB 5W-20 and OE filter at 6,000 mile intervals. Oil life monitor should be at about 40%. Did an early change at 1,000 miles.
Hey all,
Welcome to BITOG
Do you have any data to back up the statement that Redline kills the tick? Or, are you just trolling as usual?
Posted By: 77Se7en
Re: 19 Ram Rebel oil choices - 01/18/20 02:48 AM
Subie
OP hasn't a problem to fix. The tick has not developed yet and he's trying to avoid it. I have read a Ram BITOG member or two here, that's gone this exact route when the vehicle is still new and the engine remains silent using Redline.
Posted By: 77Se7en
Re: 19 Ram Rebel oil choices - 01/18/20 02:50 AM
OilReports
Where did I say it kills the tick? I recommended Red Line to the OP, to avoid the tick.
Please, learn how to read replies here.
Re: 19 Ram Rebel oil choices - 01/18/20 02:52 AM
OilReports
Sorry, My bad!
Do you have any data to back up the statement that Redline is good to avoid the tick?
Posted By: 77Se7en
Re: 19 Ram Rebel oil choices - 01/18/20 02:57 AM
Only that I've read a couple Ram Owners here that are currently using it. Read it here and over on a busy Rams board.
Re: 19 Ram Rebel oil choices - 01/18/20 03:00 AM
And that's the data you rely on to give advice to the OP?
Re: 19 Ram Rebel oil choices - 01/18/20 03:03 AM
Subie
Oil cannot "fix" an engineering blunder or manufacturing defect. It may prolong that engine's life, but it will never be a "fix". And if it were my brand new truck, I sure as heck would want an engineering blunder to fail under warranty, rather than 10k or 1 year outside of it, because then all that Redline did was drive your cost of ownership thru the roof for nothing. That's why in this case, like many others, use the cheapest oil that meets the specifications and offload it just before warranty expires.
See the threads on newer BMWs for clarification.
Posted By: tiger862
Re: 19 Ram Rebel oil choices - 01/18/20 03:15 AM
Look up TFL truck on YouTube to see long term review. They beat the snot out of the Rebel on Gas Truck Rotella 5w20.
Posted By: tundraotto
Re: 19 Ram Rebel oil choices - 01/18/20 03:24 AM
Oh the 30 minute SHELL commercial? Rotella Gas truck, Rotella Diesel oil, Top tier Shell fuel from Shell on the Shell cards.....
Posted By: madeej11
Re: 19 Ram Rebel oil choices - 01/18/20 03:37 AM
You could go the QSUD route also. Easier on the wallet and good amount of moly too. Question, is this hemi tick harming the engine or is it just annoying?
Re: 19 Ram Rebel oil choices - 01/18/20 03:45 AM
QSUD has the highest moly of the 'majors'....or if it really matters either.
Don't know about any HEMI ticks...
Posted By: john_pifer
Re: 19 Ram Rebel oil choices - 01/18/20 04:40 AM
Don’t forget that TGMO also has an almost obscene amount of moly, as well. And, from what I’ve read here, the cost is not too exorbitant, either.
Anybody here remember member Caterham? He invented the “Caterham blend”, which was, I believe, 50/50 blend of TGMO and Mobil 1 0W-40.
Maybe find the highest moly content 0W-40 you can find, and mix 50/50 with TGMO 0W-20. You’d come out with a pretty awesome ~ 0W-30.
I haven’t seen Caterham post in forever. Anybody seen a post by him lately?
Re: 19 Ram Rebel oil choices - 01/18/20 05:32 AM
Mazda had a really high 0W-20 moly oil that was even labeled as such.....for the Skyactiv engines when they first came out - lots of moly.
Posted By: 77Se7en
Re: 19 Ram Rebel oil choices - 01/18/20 11:45 AM
User data?......... yes! Sure beats Saber-Math Analysis Reports.
One has to know how there engine is doing in the long-run. It beats how the oil is doing short-term.
A perfect example is major league baseball, which is now filled with Saber Math gurus that declare math is the best method to build a 25-man roster and the best method to make decisions during games.
However, the MLB teams that have invested the most heavily into saber-math, are not in the World Series every year. So the oil sabermetric genius with all those college degrees is no better at telling me how to care for my engine, than I, who work side-by-side with my vehicles every day.
So the best reports on Dodge Ram engines are the owners themselves, not Blackstone or any diploma-hanging oil genius visiting here today. So if a long-time forum member Ram owner says his engine has no tick using RedLine oil early-on in the engine's life, that's a good sign that oil needs to be investigated further. The OP here wants to try it and I applaud his decision.
I have-yet to read a Ram owner telling us he used Red Line from early-engine-life and the tick still developed later-on. So when I read that someday, then perhaps I won't recommend Red Line anymore. Until then?...... absolutely Yes ..... and I hope it works long-term.
Posted By: The_Nuke
Re: 19 Ram Rebel oil choices - 01/18/20 12:44 PM
Instead of putting blind faith in some contrived corollary coincidence while chastising others for doing the exact same thing only with their own imaginations, here’s an idea: IDENTIFY THE SOURCE OF THE TICK.
Once the culprit is known, address it (or prevent it) accordingly. There, problem solved!
I just saved everyone lots of time, effort, money, and bickering back and forth...assuming someone takes my suggestion that is...
Really people, let’s get real with ourselves for a second. Unless the issue causing the noise is known, anything done to address it or prevent it from happening is at best a guess...an educated one, yes, but still just a guess.
Peace and hair grease,
Nuke
Posted By: dlundblad
Re: 19 Ram Rebel oil choices - 01/18/20 12:57 PM
Trying 5w30 certainly won’t hurt a thing and is worth a try. Should be allowable warranty wise too. I don’t think it necessarily needs to be Redline though.
Any name brand synthetic at reasonable intervals is what I’d do. It’ll be the same price as 5w20 too.
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 03:27 PM
I actually live within an hour of these guys and have seen that little advert they did for Shell.
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 03:31 PM
Nuke
The only way to fix it is for FCA to yank the cams and lifters out. Now, I am no expert in metallurgy and I am certainly not a petroleum engineer, but I find it rather strange that Hemi owners find that oils with higher moly content seem to add a layer of prevention to the cam wear that leads to the tick. It seems that the general consensus is to run whatever makes me sleep better at night and when the "tick" presents itself, let the warranty do its job.
So I am seeing mixed reviews in here so far, and i have to say the topics brought up are interesting so far. I appreciate each and everyone of your comments on this!
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 03:32 PM
Is there an updated list of the "majors" and the current add packs in them?
Posted By: PimTac
Re: 19 Ram Rebel oil choices - 01/18/20 03:40 PM
You can run through the latest UOAs and VOAs here. Since there are different forms of molybdenum one cannot assume that more is better. Keep that in mind.
Posted By: Schwifty
Re: 19 Ram Rebel oil choices - 01/18/20 03:54 PM
I was wondering about that, so I read there is a newer moly, tri nuclear I believe and it supposedly requires less to do the same as oils with higher moly content. Do we know which brands have started using this updated version of moly? Or do you have any reading content you can point me towards? I did visit the VOA section, I find it intriguing to see the results from a variety of different vehicles.
Posted By: OVERKILL
Re: 19 Ram Rebel oil choices - 01/18/20 04:05 PM
I don't know what the most recent engine to experience the issue is, but I believe FCA is using an updated lifter design at this juncture, so being concerned about it may be a non-issue. As Suby pointed out, you aren't fixing a materials selection or engineering issue with a lubricant. Of the 4x HEMI's we've owned, none of them have ticked and none of them have had Redline used in them. Oldest HEMI we owned was in a 2006 Charger.
Further anecdotes here:
At work, we have a number of RAM 1500's. They are all 2011-2012 vintage. They are serviced using whatever cheap bulk 5w-20 the guy doing the work on them uses, which is NAPA, so I believe that's Valvoline. Cheap NAPA filters. All of these trucks have well over 200,000Km (120,000 miles) on them, and all of them developed a tick... from the exhaust manifolds. Once the exhaust manifold studs were replaced, and the manifolds themselves straightened and re-installed, the sound was gone. We also have a couple newer trucks, a 2015 and a 2016, they are also quiet, but have significantly lower mileage, as should be expected.
Posted By: kschachn
Re: 19 Ram Rebel oil choices - 01/18/20 05:48 PM
That would be hard to identify. Nothing in a VOA will tell you that, all compounds are decomposed in an ICP and you don't know anything about the chemical structure.
There was a guy who used to post about this a lot, his name is burla. I haven't seen him lately but you can search his posts.
Posted By: SR5
Re: 19 Ram Rebel oil choices - 01/19/20 12:03 AM
Tri-nuclear Moly adds more moly atoms per ml (volume) of additive, but when you get a VOA or UOA the plasma in the AA breaks up the molecules (tri, di or mono) and counts the number of moly atoms present, and it’s the moly atoms that do the work in the engine.
So it is correct to use a VOA as a measure of moly content as it is independent of how that moly is bound to the organic part of the molecule.
You are more interested in total moly which a VOA gives. Eg 1 ml of tri-nuclear adds more moly than 1ml of di-nuclear/ mono-nuclear but that VOA process will sort this out for you and give numbers that can be compared.
Posted By: riklyn
Re: 19 Ram Rebel oil choices - 02/01/20 06:27 PM
personally, I would use an oil that meets the Chrysler spec MS6395,(if truck is in warrant)y. the owners manual is pretty clear on this.
if it's out of warranty it's not an issue.
and just for the record, I think the spec is BS, but it can be reason for a crappy dealer to deny coverage or claim that use of non spec oil caused damage. and then it's on you to prove that it didn't.
Posted By: BAJA_05
Re: 19 Ram Rebel oil choices - 02/01/20 07:25 PM
Guaranteed -- he was just TROLLING as usual.
OVERKILL nailed it right on the head -- its the exhaust manifolds -- NOT the engine.
Posted By: Nick814
Re: 19 Ram Rebel oil choices - 02/02/20 11:41 PM
I run RGT 5w-20 in my 2019 Laramie. 5k oil changes. Quiet and smooth. If its going to break with that, we have bigger problems
Posted By: RISUPERCREWMAN
Re: 19 Ram Rebel oil choices - 02/02/20 11:59 PM
Run Amsoil Signature Series oil and sleep well at night !
Posted By: GMBoy
Re: 19 Ram Rebel oil choices - 02/03/20 07:57 AM
Keep what you're doing. I run Mobil 1 5W/30 in my 2016 Ram Limited and no issues. I have no tick at 63k miles. I did have the exhaust manifold leak that sounded like a hemi tick but wasn't. Enjoy your Rebel, nice truck - I love the air suspension which I also have on my truck - no truck rides smoother or has as nice of an interior than RAM trucks. I will get another Limited in 2-3 years but for now my 16 is like new and trouble free.
Posted By: Dragon44
Re: 19 Ram Rebel oil choices - 02/04/20 01:33 AM
IV owned a few hemis and always used Schaeffer's oil (Lots of Moly B) and never had any engine tick.
Posted By: jdavis
Re: 19 Ram Rebel oil choices - 02/04/20 01:57 AM
We have a winner..
Posted By: CT8
Re: 19 Ram Rebel oil choices - 02/05/20 11:42 PM
Any oil with the proper ratings from a major company . Your engine will never know the difference.
Re: 19 Ram Rebel oil choices - 02/06/20 12:00 AM
Unless it has a tick. If it does, seek professional advice and avoid the "slug-of-moly" housewife tale.
© 2020 Bob Is The Oil Guy
