greae info
Mississippi
any one ever used Super S Hi Temp grease? its readily available?
also Kubota Hi Performance Ag grease /w moly
looking for an easy to find farm tractor grease
thanks
dave
there is an alum complex grease that has moly in it and it will not wash out.that is what I would use for a tractor. the reason is that you have to go in water and when you do it will cause the moly to wash right out the grease, you then have to re-grease your unit. with alum complex water will not mix and will leave the moly in it which is what you want. I can't remember the name of it but I do know you can get it at some of the parts stores.
