Hi,
First off thanks for an excellent site!
I have a 2006 Dodge Cummins with about 15k miles that has shown high Iron in every test. I have done a bunch of turbo work on this motor (replacing single turbo 3X's and then installing a set of twin turbos) so I'm assuming the Iron is coming from contamination while the system is opened-up. Here's my last report...
Would it be normal to see those levels of Fe from doing turbo work?
