Generac Air Filter Cross Reference
northern Alabama
I have a 16kW Generac residential generator model 05255 with the V-Twin GT-990 engine. Mfg p/n 0C8127 for the air filter.
Wix doesn't have anything listed for this filter.
I have emailed AMSOIL as well but I don't have high hopes.
Any help?
For this one, I'd say your best bet is going to be a small engine repair shop. They should be able to get their hands on one for you fairly easily.
Does that filter have any other numbers on it? I couldn't get that one to cross, but most Generac air filters start with the digits 812...., they are 5 numbers in length though.
Maybe your best bet is cross referencing by size.
I found a WIX to fit a lawnmower like that, I could not cross the oem number to anything. Took some time and effort but I lucked out with a perfect match.
If you post the precise dimensions here, you may even get help with it?
On the filter is C8127, Flame retardant, made in India CE6.
It measures 6.75" OD, ~ 5-5/32 ID. I forgot to measure height.
