Permatex has a myriad of sealers and "form-a-gasket" products in their line-up. Their application guide isn't terribly clear on their correct uses, either. It seems as though many of the products could be used for the same applications.
Is there one sealer that I can stock that will work for the following automotive applications:
Oil Pan Gasket (Cork or Rubber)
Transmission Pan Gasket (Cork or Rubber)
Differential Oil Cover
Valve Cover Gasket
Thermostat Gasket
Water Pump Gasket
Would RTV work for all of these applications? They have many different types of RTV available, which one should I use?
Thanks.
Valve Cover Gasket
Thermostat Gasket
Water Pump Gasket
Thanks.
