Quote:
Nothing IS being lost from the battery.
If this were true why do so many people here report corroded terminals on their batteries, especially the negative terminal. What happens during charging is that O and H gasses are released during electrolysis, they alone cannot corrode battery terminals, but what happens is that as they bubble to the surface of the battery they create a fine mist, this fine mist consists of electrolyte which is water + sulfuric acid. When the electrolyte mist leaves the battery it then settles on top of battery contacts, the electrolyte reacts with mostly the negative terminal, causing a one way discharge and the electrolyte turns into a white powder, the sulphate crystals which are also formed on battery plates when batteries are being discharged.
Quote:
I have *NEVER* seen any recommendation to top off a battery with acid *UNLESS* electrolyte is lost due to spillage.
And I've done a LOT of research into this.
This is why it is very counter intuitive to be suggesting adding acid to a battery, most people assume that only water is being lost either by evaporation or being broken down due to electrolysis.
Quote:
The specific gravity is going down because of "sulphation"-- "hard" lead sulphate that cannot be converted back into lead and sulphuric acid by the recharging process. This is why batteries lose capacity.
Sulphation is only one part of the reason, remember that chemistry also tells us that no chemical reaction, however violent it may be, will never completely react, there will always be some amounts of reactants or products left behind, another reason why specific gravity starts inching down. The reason why sulphated batteries lose capacity is because when batteries are left at a discharged state, or a semi discharged state these sulphate crystals harden, hard crystals are much harder to convert back to active electrolyte.
Reason why sulphated batteries lose capacity is because there crystals take up real estate on the plates, battery current is directly proportional to how much plate surface is available. Some hard crystals break off due to vibration as mentioned before, they fall to the bottom of the cell into the space underneath the plates, they are for ever lost and cannot be converted back to active electrolyte, another reason why batteries lose specific gravity.
So the question is how to battle sulphation in high heat environments, increase temperature from 10C to 20C and you are doubling the kinetic motion of the atoms. Battery that can last a full year at 10C before being discharged will only last ½ the time at 20C. Raise the ambient temp to 30C and we quadruple the kinetic motion of molecules when compared to 10C thus our battery will only last ½ of the already ½ so it will need recharging every three months.
One way is to connect the battery to a slow trickle charger, hard crystals need more time to convert back to active electrolyte. Likewise when we have a semi-discharged battery, the crystals on the plate cause resistance, the battery does not accept charge as easily so when it is blasted with a high current from the alternator voltage rises instantly to a charged state. The regulator falsely assumes that the battery must be charged as it is no longer accepting any incoming current so it drops the charging current to accommodate the state of the battery. Trickle chargers are designed to slowly force electricity back into the battery regardless the charge level, thus helping to battle sulphation.I personally use a much hated de-sulfator here on all my batteries as it has produced consistent results across a wide range of batteries. And believe me, heat in the central valley punishes all of my batteries, no matter how good they may be.
Quote:
I fail to see how adding acid to the battery can resolve this problem.
When we decrease the specific gravity of electrolyte, it is much tougher for ions to get from one plate to the other. This is called resistance R, when batteries are charged or discharged they dissipate heat due to (Isquare)R loss. So the lower the R in our equation, the higher the efficiency of our battery.
Sometimes when new ideas are being brought forth we as humans tend to look at them like the prisoner in the Allegory of the Cave written by Plato, new knowledge is like the sun light striking out eyes, it hurts we don’t like it because we have never seen the sun before, we want to close the door and go back to our old ways of thinking or doing things as we feel much more comfortable in our old world that the new.
