I know there is no truly best oil, but if you were the owner of a recently purchased 2002 QX4 Infiniti (Nissan Pathfinder) which has the all aluminum 3.5-liter DOHC V-6 (also used in the Maximma) that produces 240 horsepower and 265 lb.-ft. of torque, what would you use?
BTW, the car appears to be in very good condition and has just 65K miles... It runs very smoothly, however I am detecting slight lifter noise when the engine is at idle. Perhaps I should run Auto-Rx through one time and then start a new regiment of high quality oil?
All suggestions appreciated and welcome!
bradesp
bradesp
