Many have experienced oil leaks when using synthetic oil, especially when changing from Dino to Synthetic Oil. The reason for oil leaks when using synthetic oil is because synthetic oil cleans away the crud - same reason as why Autorx can cause initial oil leak. (I am not talking about very old engines that came with seals that are not compatible with synthetic oils)
As such, just like AutoRx, does it not also mean that once the Synthetic Oil finally washed away all the crud surrounding the seals and allows fresh oil to lubricate the dry seals, the leaks should stop.
In short, when using synthetic oil and experience leaky seals, just increase frequency of oil changes and leaks should stop - just like what Autorx does.
Do I make sense?
Do I make sense?
