hi, first a couple of questions about greasing rubber suspension bushings -
is it ok to grease rubber bushings on suspension parts on a regular basis (5-10kmiles) or is there any harm done ?
and if you grease and how does it really help ? the moving joint is "inside" the bushing so I guess the grease will never reach the joint(?)
And finally what grease should I use ?
Thanks!
Thanks!
