I don't think he wants to spend the money. Truck has 129,000 miles and cost him around $1500. He had said that it ran smoothly, which is somewhat puzzling because I was told if one cylinder was bad on compression it would show up in a rough running engine. We'll have him reevaluat that. Also possible his mechanic flubbed the comp test on that cylinder and it is not quite so bad. Definietly deposts on that plug though and the other plugs looked fine.
Maybe that cylinder runs hotter for various reasons (leaner as on end, water jacket inadequate in that area, bad plug wire, etc.) and the ring gummed up only on that one cyl. Definitely some solvent or AutoRx to help free ring would be worth a shot. Do all the low cost, can't hurt/may help things first. Can always spend the bucks later if not satisfied.
Don't know oil consumption as he only got the truck this Monday. Does not blow blue smoke anyway, so it is not a fogger.
Thanks, keep the ideas/thoughts coming. Paul
