Hi and thanks in advance. I would like to know where the inertia switch is located on my 95 Caprice Classic 4.3L. The switch that kills the fuel pump in the event of an accident. That is if the car even has one. I have intermittent starting problems where the fuel pump is not kicking in and the car cranks and cranks, and have reason to believe this switch is at fault.
It will run perfectly for weeks with no issue then won't start, then will start w/o issue. The fuel pump is new, and proper operation was verified on re-check by mechanic for same problem.
Thanks
Frank D
Thanks
Frank D
