i have a camaro with a 400 small block chevy in it, bored .030 over. its a fresh build with maybe 500 miles on it and some track passes. from here on out it will be a drag car only. mild build, i'd estimate 400-450 hp. i won't turn it over 6,000. running 110 cam2 gas now but may eventually switch to 93 octane with the Torco Accelerator additive. Compression ratio is about 11:1. i have no clue what the bearing tolerances in it are and not sure of cam type (hydraulic roller I think but not 100% sure). unfortunately it has a leak either at front of pan or timing cover, not sure of source yet and not ready to fix that yet. I want to stick with a readily available dino oil at least for now. i was thinking of running a heavy duty diesel oil like Shell Rotella T 15w 40 or Delo 400 15w 40. What oil would you folks recommend for this motor?
also, does that weight sound about right... ambient racing day temps will generally range from 40-95 degrees F. was thinking about the VR1 valvoline 20W50 but that's just too think in my opinion. The engine builder had recommended straight 30W or 40W in summer. But I tend to concur with Valvoline's site which I was reading, that said they will be phasing out their straight weights b/c multi viscosity oils do everything straights do and more. thanks.
