how's the pump?
Well I've driven the Aerostar about 350 miles now with the new pump and it is working fine. Quieter than the old one. I am not seeing a leakage issue with the rack. Think it was just some residue from the other leak. So probably won't need any additives at this time.Quote:
how's the pump?
I put Type F in (which is mineral) when I changed out the AutoRx treated fluid. I really hadn't noticed the leak come back, but my mechanic told me it was leaking when I had it in the shop so I had them replace the seal at that time. So guess I'll never know if it was really a problem or not.Quote:
TallPaul,
The leak stopped with ARX installed into your power steering unit, then began to leak again once you changed the fluid.
Did you refill with a synthetic based fluid or a mineral oil base power steering fluid?
The reason I ask is, that after cleaning a seal with ARX, it is recommended that a mineral oil be run to shrink or stiffen the rotation seal material, to re-seal. Synthetics tend to keep the seal soft or limp.
Quote:
Don't leave BITOG, GMorg. I have felt the same as you do. BITOG, like most forums, is full of poor posts showing many of the bad sides of humans. But there are some occasional gems posted by a relatively small group of people. You are one of those people and if you leave, that just makes the group of informative posters smaller. Posting less is a good tactic though which may ease your frustration but still provide some satisfaction. Look for the gold nuggets and pass over the turds.
Quote:
and then told me they quit making Type F and the Dextron III would be fine, just to not use anything synthetic.
It's also listed currently at the Motorcraft website.Quote:
i saw type F at wally world tonight.
