01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Subaru Forester with rusty brakes
by Donald - 12/14/19 12:55 PM
2017 Honda CRV, 1.5 Turbo, Mobil AFE 0W-30
by 06_lx - 12/14/19 11:48 AM
Toyota WS ATF or Aisin WS ATF
by dblshock - 12/14/19 10:28 AM
Bauer Dual Action Polisher
by TheLawnRanger - 12/14/19 10:12 AM
Questionable Tool Cart/Nice Price
by TheLawnRanger - 12/14/19 09:57 AM
Craftsman Tool Cart at Ace
by TheLawnRanger - 12/14/19 09:52 AM
Looking to buy a oscillating saw
by JLawrence08648 - 12/14/19 07:46 AM
What's your favorite handgun?
by Silverado12 - 12/14/19 07:07 AM
DOT3 or DOT 4 Brake Fluid ?
by ChrisD46 - 12/14/19 06:34 AM
Jumping Ship To Castrol Magnatec ?
by ChrisD46 - 12/14/19 06:21 AM
Simoniz Ceramic Spray Wax
by Toros - 12/14/19 05:48 AM
Pep Boys- got screwed again on battery
by rubberchicken - 12/14/19 01:48 AM
Electrocars strike back
by SlavaB - 12/14/19 01:41 AM
What happened to the 90 octane e15?
by Rmay635703 - 12/14/19 12:55 AM
Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 12/13/19 10:50 PM
General RT43 or Conti TrueContact Tour
by Propflux01 - 12/13/19 10:16 PM
merrittgene, 4Cyl, Cage3013, chadder1313, Sumo91
70124 Registered Users
79 registered members (andyd, antonmnster, 06_lx, 4WD, 53' Stude, 8 invisible), 2,161 guests, and 23 spiders.
Topics298,802
Posts5,141,385
Members70,124
Most Online3,589
Nov 2nd, 2019
The Story With Additives - Rebuttal #803373 01/04/07 06:28 PM
H
heathenbrewing Offline OP
H
I do see where this test could prove some points and where it can also use a bit more re-testing. Due to the fact that this device they used doesn't generate the same amount of heat that an engine block would or a differential, some of the facts they proved were not 100% true b/c they didn't add in a temperature factor. Cooler air has more oxygen in it correct? Correct. So, if these machines are run at room temperatures or basically, any temperature below standard engine operating temperature, they are flawed. As the oil is heated up throughout the block, any air trapped within the oil or the block itself is evaporated/disintegrated into it's molecules. With the constant heat found within the engine block, I would suspect that the air bubbles found in this test would be very minimal in a real engine block or differential test.
But, I do see how this test can have some validity in just presenting numbers, but not as much in a real life test.
Your thoughts?
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803374 01/04/07 06:39 PM
doctorr Offline
Your post would probably make more sense if it was in the thread where it all started....
As is, I can only ask "what test?" and "what device?" etc.
doc
Re: The Story With Additives - Rebuttal [Re: doctorr] #803375 01/04/07 06:42 PM
P
Patman Offline
Global Moderator
Global Moderator
P
He's referring to the additives story on the main page of this site.
2018 Corvette, 17k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 152k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,121k, GC 0w40 & Fram Ultra
Re: The Story With Additives - Rebuttal [Re: Patman] #803376 01/04/07 07:38 PM
H
H
Oops..my bad. Heres the article in question:
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803377 01/04/07 07:51 PM
Y
yugrus Offline
Y
The air itself is the mixture of different gases, most of it is Nitrogen, the Oxygen comes second.
I don't see how the air, being gas, would evaporate. It can not disintegrate further down then N2, O2 and the rest. So the bubbles will still be air, heated-up, but air.
Because the gas tends to expand when heated, the bubbles will most likely tend to be bigger and less stable in the oil that is thinner because of the heat.
So the final outcome at operational temperature might indeed be different, the aeration could be less.
But then the tests are valid during the cold start-up, and that's when you get most wear...
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: The Story With Additives - Rebuttal [Re: yugrus] #803378 01/04/07 09:02 PM
H
H
Thanks...was trying to answer a comment by another Scion owner. I stopped taking caffiene, so I am a bit slow in the mornings.
That says it all for me. Thanks!
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803379 01/05/07 02:28 AM
R
rpn453 Offline
R
That demonstration doesn't directly simulate any specific real-world application. It simply demonstrates that undesirable things can happen when you modify a lubricant that is already engineered and proven to be suitable for a specific application.
2004 Mazda3 GT Hatch 75k
