Oil for DI
by Coastie05. 06/18/19 01:57 PM
Edge or Edge EP for friends Venza
by 53' Stude. 06/18/19 01:11 PM
Found a Premium Blue Restore VOA
by SubyRoo. 06/18/19 12:44 PM
Semi-Syn
by nicholas. 06/18/19 11:30 AM
Particle Count (PC) testing of used oil
by Talent_Keyhole. 06/18/19 11:25 AM
Added individually, coolant & water won't mix?
by Ed_Flecko. 06/18/19 11:15 AM
02 silverado diff fluid....
by Jcountry. 06/18/19 11:06 AM
Arteries
by CourierDriver. 06/18/19 10:17 AM
Remember the Officers
by CourierDriver. 06/18/19 10:02 AM
New TV
by WyrTwister. 06/18/19 08:45 AM
Best cheap filter?
by jayjr1105. 06/18/19 08:37 AM
BB Pistol- The Peacemaker
by CourierDriver. 06/18/19 06:33 AM
Zoro.com 20% off sale
by SubieRubyRoo. 06/18/19 06:24 AM
Why such a low temp thermostat?
by Chris142. 06/17/19 11:21 PM
Abnormal Wear on Tire?
by A_User55555. 06/17/19 11:17 PM
Jag F Type
by Snagglefoot. 06/17/19 11:00 PM
Autozone $7 Coupon
by TheLawnRanger. 06/17/19 10:00 PM
Petethedog, RenewableLubeBen, flattire101, Score294, PublicStellar
68426 Registered Users
96 registered members (53' Stude, aquariuscsm, Alfred_B, 1978elcamino, 9050lx, AlienBug, 8 invisible), 2,178 guests, and 30 spiders.
Topics290,618
Posts4,989,623
Members68,426
Most Online2,967
Mar 10th, 2019
The Story With Additives - Rebuttal #803373
01/04/07 07:28 PM
01/04/07 07:28 PM
CA
heathenbrewing Offline OP
CA
I do see where this test could prove some points and where it can also use a bit more re-testing. Due to the fact that this device they used doesn't generate the same amount of heat that an engine block would or a differential, some of the facts they proved were not 100% true b/c they didn't add in a temperature factor. Cooler air has more oxygen in it correct? Correct. So, if these machines are run at room temperatures or basically, any temperature below standard engine operating temperature, they are flawed. As the oil is heated up throughout the block, any air trapped within the oil or the block itself is evaporated/disintegrated into it's molecules. With the constant heat found within the engine block, I would suspect that the air bubbles found in this test would be very minimal in a real engine block or differential test.
But, I do see how this test can have some validity in just presenting numbers, but not as much in a real life test.
Your thoughts?
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803374
01/04/07 07:39 PM
01/04/07 07:39 PM
North Canada
doctorr Offline
doctorr  Offline
North Canada
Your post would probably make more sense if it was in the thread where it all started....
As is, I can only ask "what test?" and "what device?" etc.
doc
Re: The Story With Additives - Rebuttal [Re: doctorr] #803375
01/04/07 07:42 PM
01/04/07 07:42 PM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
He's referring to the additives story on the main page of this site.
2018 Corvette, 12k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 150k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,114k, GC 0w40 & Fram Ultra
Re: The Story With Additives - Rebuttal [Re: Patman] #803376
01/04/07 08:38 PM
01/04/07 08:38 PM
CA
CA
Oops..my bad. Heres the article in question:
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803377
01/04/07 08:51 PM
01/04/07 08:51 PM
ON, Canada
yugrus Offline
yugrus  Offline
ON, Canada
The air itself is the mixture of different gases, most of it is Nitrogen, the Oxygen comes second.
I don't see how the air, being gas, would evaporate. It can not disintegrate further down then N2, O2 and the rest. So the bubbles will still be air, heated-up, but air.
Because the gas tends to expand when heated, the bubbles will most likely tend to be bigger and less stable in the oil that is thinner because of the heat.
So the final outcome at operational temperature might indeed be different, the aeration could be less.
But then the tests are valid during the cold start-up, and that's when you get most wear...
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: The Story With Additives - Rebuttal [Re: yugrus] #803378
01/04/07 10:02 PM
01/04/07 10:02 PM
CA
CA
Thanks...was trying to answer a comment by another Scion owner. I stopped taking caffiene, so I am a bit slow in the mornings.
That says it all for me. Thanks!
Re: The Story With Additives - Rebuttal [Re: heathenbrewing] #803379
01/05/07 03:28 AM
01/05/07 03:28 AM
Saskatchewan
rpn453 Offline
rpn453  Offline
Saskatchewan
That demonstration doesn't directly simulate any specific real-world application. It simply demonstrates that undesirable things can happen when you modify a lubricant that is already engineered and proven to be suitable for a specific application.
2004 Mazda3 GT Hatch 75k
