Just came back from Baja California, Mexico after installing a skid mounted gen set. I was asked to go up into the hills to look at a homemade generator set that supplied electricity for a family living off the grid. The engine was a Buda with a manu date of 1926. The interesting thing is that it has toilet paper oil and gas filters. The 55 year old farmer told us his 75 year old father fabricated the filters during WWII when oil became scarse. They now, don't change oil, ever, just filters and makeup oil. Oil travels though a screen and then a stack of disc's acting as a full flow filter. This can be taken apart and cleaned. Some oil at full pressure goes through a small orifice for each filter (one about 60 thou and the other a bit smaller) and two toilet paper bypass filters in a parallel path. Each filter has three rolls, end to end. The gasoline also has a single three roll filter.
I was asked if I had any suggestions for improving the installation or the maintenance. I told them that I should be the one asking for advise. The fabrication, given the conditions was a work of art. I stayed and helped them fabaricate a crankcase breather/seperator, and paper element air filter housing to replace their oil bath filter and taught them how to gas weld with 3003H14 aluminum and gave them a case of air filters, some blue gogles (helps to see what's happening when welding aluminum), flux and welding rod to play with as they polish their up their skill. Father, son and grandpa are great craftsmen and have the farmers skill to engineer and fix just about anything.
My question is this. Are these guys are early adapaters of toilet paper technology. They told me that they learned this from family members that ran a fishing boat.
