Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
24 registered members (bmod305, Black_Thunder, AnthemBassMan, bfleeman, Brad_C, 555, 2 invisible), 489 guests, and 68 spiders.
Topics286,263
Posts4,905,495
Members67,589
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Brake bleeding: pressure or vacuum? #787908
12/14/06 04:33 AM
12/14/06 04:33 AM
usa
par Offline OP
par  Offline OP
usa
Let's keep this strictly to brake bleeding.
If you were to buy one device to help bleed brakes, then would it be a pressure unit such as the Motiv, or a vacuum unit like the Mity-vac? Let's also assume cost is not an issue and base our decision on the merits of each method.
Re: Brake bleeding: pressure or vacuum? [Re: par] #787909
12/14/06 05:46 AM
12/14/06 05:46 AM
Ontario , Canada
Idrinkmotoroil Offline
Ontario , Canada
for a one person bleeding system I've always liked vacuum methods, they work prety well. I don't know much about the Motiv setup to be honest with you but any vacuum setups I've used are real simple and effective.
Re: Brake bleeding: pressure or vacuum? [Re: Idrinkmotoroil] #787910
12/14/06 07:04 AM
12/14/06 07:04 AM
RI
unDummy Offline
unDummy  Offline
RI
I'd use and recommend any pressure bleeder 1st over a vacuum bleeder.
I'm also a speedbleeder junkie.
Re: Brake bleeding: pressure or vacuum? [Re: unDummy] #787911
12/14/06 07:37 AM
12/14/06 07:37 AM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
I used Motive Bleeder on several cars, it is the easiest hand tool to bleed the brake, specially for Euro cars such as MB or BMW, no chance for air to get in the brake lines. I have Mityvac 7201 to change oil, transmission fluid; changing oil for newer MB is super easy with Mityvac.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Brake bleeding: pressure or vacuum? [Re: HTSS_TR] #787912
12/14/06 07:41 AM
12/14/06 07:41 AM
Ohio
KBFXDLI Offline
KBFXDLI  Offline
Ohio
Why do you guys prefer power to vacuum?
KB-FXDLI. GC ist für deutsche Amerikanerautos der Auto-nicht
Re: Brake bleeding: pressure or vacuum? [Re: KBFXDLI] #787913
12/14/06 08:16 AM
12/14/06 08:16 AM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
With Motive Bleeder you don't worry about low brake fluid in reservoir if you have enough fluid in the bleeder tank. With vacuum tool, you need to watch the old fluid comming out of bleeder valve and also watch and top off fluid in the reservoir.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
Re: Brake bleeding: pressure or vacuum? [Re: HTSS_TR] #787914
12/14/06 08:46 AM
12/14/06 08:46 AM
RI
unDummy Offline
unDummy  Offline
RI
Read my comments in the thread "MityVac Evacuator -Bleed Brakes First Time" in this forum.
Re: Brake bleeding: pressure or vacuum? [Re: unDummy] #787915
12/14/06 08:55 AM
12/14/06 08:55 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
i use a mityvac, MATCO rebranded, shop air powered vacuum bleeder at work. works really well and will draw about 2 quarts in a minute. i dont have to worry about the master leaking down because i use an auto refiller. basically its a little tank you put on the master and it will drip brake fluid while the level drops.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Brake bleeding: pressure or vacuum? [Re: bdcardinal] #787916
12/14/06 03:22 PM
12/14/06 03:22 PM
Thousand Oaks, CA
Big Jim Offline
Big Jim  Offline
Thousand Oaks, CA
This is one of those cases where it is good that there are different tools and techniques available.
There is no one best answer for all cars. By know the different methods available, alternatives can be used when the system doesn't respond to your normal method.
I like the vacuum method. It almost always works for me. With the right tool is is quick and painless. Sometimes with a stubborn system other methods need to be applied including the two person bleed, pressure, and gravity.
Which system works when all else seems to fail? Gravity.
Re: Brake bleeding: pressure or vacuum? [Re: Big Jim] #787917
12/14/06 09:21 PM
12/14/06 09:21 PM
Ohio
KBFXDLI Offline
KBFXDLI  Offline
Ohio
I have a motive extractor and they give you a hose for brake bleeding with it. I have a new vehicle and am considering bleeding the system once a year as part of my annual routine. Do you guys bleed the furthest wheel first or last?
Re: Brake bleeding: pressure or vacuum? [Re: KBFXDLI] #787918
12/15/06 12:02 AM
12/15/06 12:02 AM
Lake Forest, CA
HTSS_TR Offline
HTSS_TR  Offline
Lake Forest, CA
Farthest wheel first: Passenger rear, driver rear, passenger front and driver front last.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
Re: Brake bleeding: pressure or vacuum? [Re: HTSS_TR] #787919
12/15/06 12:08 AM
12/15/06 12:08 AM
Agrestic, CA
Laminar Lou Offline
Laminar Lou  Offline
Agrestic, CA
I've got both setups. I like the pressure bleeder better because I don't have to lug the hand vac setup to each brake. I just slip on a hose and turn the bleeder until I see the new fluid.
I alternate a blue fluid with an amber fluid so I can see when everything is purged (although that would obviously work for a vacuum method).
I have a Motive and a Mighty Vac. I use the might vac on the motorcycles but switched to speedbleeders on them.
Re: Brake bleeding: pressure or vacuum? [Re: Laminar Lou] #787920
12/15/06 06:47 AM
12/15/06 06:47 AM
Ohio
KBFXDLI Offline
KBFXDLI  Offline
Ohio
I think I am sold on the motive power bleeder because I'll always be doing this alone.
Re: Brake bleeding: pressure or vacuum? [Re: HTSS_TR] #3492324
09/24/14 03:28 PM
09/24/14 03:28 PM
Switzerland
volodymyr Offline
volodymyr  Offline
Switzerland
HTSS_TR,
Actually there are several vacuum kits which allow you to hook a bottle with new fluid to reservoir so it does not get dry.
2001 Honda CBR 600 F4i, Castrol Power 1 Racing 4T 10W40 (SM,MA2)
2010 Nissan Qashqai 2.0, Shell Helix Ultra 5W30 (A3/B4,MB 229.5,502.00/505.00)
Re: Brake bleeding: pressure or vacuum? [Re: bdcardinal] #3492329
09/24/14 03:32 PM
09/24/14 03:32 PM
Switzerland
volodymyr Offline
volodymyr  Offline
Switzerland
Hello bdcardinal,
I am considering to buy vacuum bleed kit, however since I don't have compressor I need to choose it as well. Can you tell me if any cheap compressors which work from accumulator battery will do the job? Any hints on minimum pressure of the system are also welcomed ...
Thanks!
Page 1 of 3 1 2 3
