Where I live in NY, if your '96 or newer car shows that the check engine light is on, your car will fail the required annual inspection. Can I just pull out this light bulb or cut the wires? or will the car start to go spastic when this happens? This check engine scenario has to be taken care of, and many times it's an expensive solution.
