ford3liter, I'm not surprised that the engine runs smoother (revs easier, labors less) and uses less gas. 20W-50 is far too thick to run in these motors. MolaKule ran a test with various oils and found that 20W-50 made his single cylinder engines actuallu run hotter because of the greater drag on the motor.
I will run 15W-40 in these engines and give up a little fuel economy in exchange for a slightly thicker film of oil and a killer additive package ... while still getting easier starting over the oft-recommended straight 30 weight.
For newer, tighter engines I will run this stuff thinned out by a 5W-30 or 10W-30 for even easier cold-weather starting.
I'm a little leery of going with XW-30s or XW-20 oils ... especially ones that aren't terribly shear stable. How does the oil look when you drain it? I'd be worried about lower-end wear.
Amazing that you say the motor doesn't burn any oil even at high RPMs.
